Author Topic: E-Touch V7 Released with New Demo, STREAMING SUPPORT ADDED!  (Read 5734 times)
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« on: March 25, 2011, 01:33:39 pm »
Main App:
BUG: If tack title was not tagged alternate versions crashed juke (FIXED)
BUG: Internet songs would not play from hot hits correctly (FIXED)
BUG: Clicking online search button didn't update the top label with the right search term (FIXED)
BUG: Quick search boxes when searching on albums were odd. (FIXED)
BUG: Playing online songs from history doesn't show right tag info on play options screen. (FIXED)
BUG: Can't scroll down through online results most of the time. (FIXED)
BUG: History didn't show online cover for streamed songs. (FIXED)
BUG: Credits didn't save on shutdown (FIXED)
BUG: Show next didn't show streaming_file.jpg for cover (FIXED)
BUG: Queue didn't show streaming_file.jpg for cover (FIXED)
BUG: Second screen code on engine 1 was not the same as main for hanging prevention (FIXED)
BUG: Clicking on some labels from search results gave incorrect tag info for online songs (FIXED)
BUG: Dual screen stopped working (FIXED)
BUG: Second screen wouldn't process songs (FIXED)
BUG: Using second screen you couldn't slide the progress bar to skip through song (FIXED)
BUG: Intergrate Online Search Results option didn't save (FIXED)
BUG: Streaming_file.jpg wasn't used if use first cover found was checked (FIXED)
BUG: Clicking an online track cover in Search, History or Queue brought up tracklisting (FIXED)
BUG: Newley added DB wasn't showing correctly. (FIXED)
BUG: Streaming song pricing broke random play using playlist (FIXED)
BUG: Reset meter didn't wrok from E-touch (FIXED)
BUG: Run app label said freebox, changed to jukebox. (FIXED)
BUG: Queue didn't update when moving to next song (FIXED)
BUG: Streamed song in queue could show wrong tag info (FIXED)
BUG: Pin request for search screen showed search behind album view when pin entered (FIXED)
BUG: Pin request for decades screen showed decades behind album view when pin entered (FIXED)
BUG: Integrated search, clicking cover for streaming song didn't show tag info (FIXED)
BUG: Fanart caused a crash if : was in the artist name (FIXED)
BUG: Grey box around internet seach results on no songs found screen (FIXED)
BUG: Most played didn't work in random as it was using the old "most played.cvr" file (FIXED)
BUG: Keep queue shown didn't show queue until it was clicked. (FIXED)
BUG: playing streaming songs whilst logged into e-touch corrupted your user (FIXED)
BUG: clicking most popular song under My E-Touch caused an error if it was streamed (FIXED)
BUG: Most played wasn't generated correctly (FIXED)
BUG: The charging code was wrong and might have caused issues (FIXED)
BUG: Limit artist in queue wasn't working correctly (FIXED)
BUG: Queue didn't save out correctly (FIXED)
BUG: Videos don't show in newley added even if combo box is set to pick them up. (FIXED)
BUG: Adding songs from most played didn't require credits (FIXED)
BUG: Jingle wasn't set as random song so would play through if a user song was added (FIXED)
BUG: Queue saving and loading wasn't working (FIXED)
BUG: Show Next didn't update if queue was emptied (FIXED)
BUG: Queue duration didn't show correctly (FIXED)
BUG: Search when on most played didn't work (FIXED)
BUG: Cut off random song doesn't work (FIXED)
BUG: All songs play at the random song level (FIXED)
BUG: Selecting a song in queue and clicking play now plays wrong song (FIXED)
BUG: Clicking a cover in queue displays wrong album tracklisting (FIXED)
BUG: Search when newly added is selected doesn't work (FIXED, searches audio)
BUG: Queue doesn't show duration (FIXED)
BUG: Move Up/Down Queue doesn't work (FIXED)
BUG: Cutting off a random song charge the play now value (FIXED)
BUG: player backdrop didn't load if set from texture viewer (FIXED)
BUG: hiding player controls didn't hide pop up player button (FIXED)
BUG: Queue was not saving out correctly due to adding the duration (FIXED)
BUG: Letters on genre screen didn't load causing a crash (FIXED)
BUG: Show Next caused a crash if there was no cover (FIXED)
BUG: Playing a streamed song from hot hits showed wrong tag info (FIXED)
BUG: Ability to have a pin for my E-Touch didn't work (FIXED)
BUG: If last page had full albums it would lock up if you paged down (FIXED)
BUG: Certain regions wouldn't accept the licence file (FIXED)
BUG: PAUSED Label didn't skin (FIXED)
BUG: Pop player would pop up after a search was performed (FIXED)
BUG: Turning off keyboard highlighting didn't remove highlight box from pop up menu (FIXED)
BUG: New album screen credit label showed even if credits were not enabled (FIXED)
BUG: If stop random song on user selection was on play next still added to queue (FIXED)
BUG: Slider and Jump to letter didn't work for A (FIXED)
BUG: Coming up next wasn't transparent sometimes (FIXED)
BUG: Jump to letter pop up didn't dissappear when you selected a letter (FIXED)
BUG: Pop player would pop up after a decades chart was performed (FIXED)
BUG: Album coovers had a border around them (FIXED)
BUG: time to wait between tracks on random was also affexcting the queue (FIXED)
BUG: If track or artist had & it caused issues with alternate track (FIXED)
BUG: Didn't launch config on first start if no DB's were created (FIXED)
CHANGED: Karaoke DB is now dynamic array so no limits on size
CHANGED: Queue handling is totally re-written to be faster
CHANGED: Warning message for online songs shows when selected not when played
CHANGED: Debug window has been improved to provide more info when running /D
CHANGED: Tried to tidy up the track and artist titel some more for online songs
CHANGED: Default skin changed so online results are larger and easier to click
CHANGED: Quick search selections at the top totally re-written to be much faster.
CHANGED: Switches to album screen on attract mode if you have now playing screen always on
ADDED: Support for jump to letter directly on the genre screen
ADDED: Internet streamed songs offered if search returns no results
ADDED: Internet streamed songs can now be scrolled through with up/down buttons
ADDED: streaming_file.jpg is loaded from the skin if found for stearming song cover
ADDED: Search online button added to search results screen if the returned songs are not what you want
ADDED: Ability to disable or enable the onle stuff (Currently under QUEUE options in options screen)
ADDED: Code to read the intergrate online songs into search results check box
ADDED: Option to pick what libraries to use for newley added
ADDED: Seperate costing for streamed songs.
ADDED: Code to keep queue displayed if set in the skin.
ADDED: Option to enable or disable pin coded genres
ADDED: Option to stop random song playing on user selection
ADDED: Support for pop up played added.
ADDED: Queue is saved out as hidden
ADDED: Clear QUEUE button to queue settings
ADDED: Close button to pop up player
ADDED: Audiogenie3.dll this is the latest version and should improve tag reading.
ADDED: 0 to the pin screen
ADDED: label for the pin screen
ADDED: Credit label on album screen as per coffees request
ADDED: Code to support skinned PIN for My E-Touch
ADDED: Ability to have a pin for my E-Touch
ADDED: You can now lock the player position slider so it can't be skipped
Skintool:
BUG: Pop up player didn't save out correctly (FIXED)
BUG: Couldn't set the colours of the pop up player button or nave buttons outside the album view
BUG: Pop up player background didn't save out correctly (FIXED)
BUG: Some of the labels couldn't be positioned on the play options screen (FIXED)
ADDED: Option to have pop up player controls
ADDED: Ability to skin the internet streamed song offering online_search.bmp is default backdrop.
ADDED: Ability to skin the internet streamed song Up/Down buttons
ADDED: Ability to skin search online button on search results screen
ADDED: Option to keep queue displayed
ADDED: Snap To Grid support for on screen letters on genre screen
ADDED: Snap To Grid support for search keyboard numbers
ADDED: Snap To Grid support for jump to letter screen
ADDED: Snap To Grid support for my E-Touch Login Screen
ADDED: Align X now supports search screen keyboard numbers
ADDED: Set Pin button can be skinned
ADDED: Credit label on album screen can be skinned
ADDED: Ability to have 0 skinned on the pin screen
ADDED: Ability to skin the label on the pin screen
Config:
BUG: Crashed with file error on exit if some files were set to hidden (FIXED)
Credit Module:
Setup.EXE
CHANGED: Default skin fixed up some more and added the Set Pin button in
V7.0.00 Download Thred Here
NOTE:
Here it is finally the long awaited V7 release, there are tons of new features in this release along with speed improvements and bug fixes. The biggest inclusion is the support for streaming songs if you search for songs not included in your library. Please note there has been a price increase, this is the first one in 4 years. The registered version now costs $35 and is still one of, if not the cheapest touchscreen jukebox out there. The commercial version is still $250 with deals on bulk licences as always. The biggest feature is STREAMING, you need to try this out.
As always, have fun..
Please post any support questions over on the Freebox/E-Touch forums.
Also I have made V3 availble to anyone registered over on the forums to celebrate the release of V7, it is totally free and un-restricted, come and sign up and grab yourself the demo V7 and the free V3.
Re: E-Touch V7 Released with New Demo, STREAMING SUPPORT ADDED!
« Reply #1 on: March 27, 2011, 04:07:43 am »
Awesome!
How does the streaming work exactly? Love Freedbox Barry - keep up the good work.
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
« Reply #2 on: March 27, 2011, 08:58:29 am »
If you have your jukebox connected to the internet, use search in the search feature for a song you dont have locally, it will find it for you via the internet. You cant download the song but it will play. The only caveat is no guarantee of quality of song (kbps, song length, title, edit version). Most songs sound great. Ive only played 2 that didnt match up to the search. 1 was song length (didnt play all the way) and the other one was they didnt have it titled correctly.
All in all, it works GREAT!
Fordman
ntk
  • Last login:June 06, 2011, 12:09:59 pm
« Reply #3 on: April 01, 2011, 12:55:52 pm »
this software support dual screen ?
alarsuel
  • Last login:November 07, 2011, 02:20:41 pm
« Reply #4 on: April 01, 2011, 01:39:58 pm »
Yep.  Many use dual screen for videos, karaoke, etc.
« Reply #5 on: April 01, 2011, 02:30:37 pm »
Has berries seen this?
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #6 on: April 12, 2011, 08:53:51 am »
Main App:
BUG: My E-touch showed on first load but was unchecked (FIXED)
BUG: 0 couldn't be input for delegate or admin pin (FIXED)
BUG: Quicksearch didn't clear on no quick search results (FIXED)
BUG: Attract mode would flick up album cover screen brifely on transition (FIXED)
BUG: Now playing showed label 16 on load (FIXED)
BUG: Random play on years or artists could play blocked genres (FIXED)
BUG: Licence Agreement screen didn't load properly (FIXED)
BUG: Licence agreement button would not stay turned off on load (FIXED)
BUG: Happy hour settings would not load (FIXED)
BUG: if you only have POWER OFF Enabled for delegate it didn't show (FIXED)
BUG: Require pin to shutdown didn't work correctly (FIXED)
BUG: Crash if credit divider was set to less than 1 (FIXED)
BUG: If you had disable key mapping unchecked attract mode wouldn't start on certain screens (FIXED)
BUG: Happy hour was set up wrong first day should be sunday, this caused a bug (FIXED)
BUG: Happy hour was set up wrong still this caused a bug (FIXED)
BUG: Now playing wasn't clearing properly, few bugs with it(FIXED)
BUG: Checking to hide quickjump covers didn't work (FIXED)
BUG: Most Played still showing "&" incorrectly as "&&" for Album Name.(FIXED)
BUG: Could hang with combo4_change error in logfile (FIXED)
BUG: Playlist ADD ALL To Queue didn't have correct tag info (FIXED)
BUG: Random play for playlist didn't work and could cause it to hang (FIXED)
BUG: Html\SWF for attract mode setting didn't save (FIXED)
CHANGED: Key shortcut screen in options to fit more on the screen for coffees requests
CHANGED: Add Album to Queue/Playlist is much quicker
CHANGED: Browsing track list should be much quicker paging through tracks
ADDED: Genreate a most_played.DAT to speed up loading.
ADDED: HTML/SWF Attract mode added
ADDED: Happy Hour code should now work as designed
ADDED: Happy Hour information now saves and loads correctly
ADDED: Licence button to menu and popup menu.
ADDED: Place holders for happy hour in credit options screen.
Config:
BUG: Mask.ini had *.m4a duplicated (FIXED)
BUG: Path to E-Touch launch was wrong (FIXED)
Skintool:
The following label backgrounds changed to transparent as per skinner request;
-The pin entry label
-The search field and intelli labels in the search page
-The request track labels on the request track page
-The save playlist entry field label
-The Chart selector labels
ADDED: Ability to skin licence buttons
ADDED: Ability to skin licence page (Loads licence_page.jpg from app dir for background)
Non MP3 Tagger:
Bug: The non-mp3 tagger options for setting case don't work. (FIXED)
History Edit:
ADDED: Sort By Columns
Download Thred:
http://www.freeboxjukebox.com/Forum/index.php?topic=3320.0
NOTE:
New features:
Happy Hour, if using coins you can set certain times of certain days to switch to freeplay.
HTML/SWF Supported for attact mode screens.
LICENCE SCREEN for commercial operators
Changes:
Lots of speed improvements mainly to the quick search results and when adding an album to the queue.
As always let me know of any bugs
