Author Topic: A couple MAME/MALA questions  (Read 2926 times)
Well Fed Games
  • Delicious!
« on: March 24, 2011, 01:22:52 pm »
Forgive me if these are dumb questions... I've searched around but I'm slow when it comes to PC stuff (my last cab was a PS1 shoved in a box with a TV):
1. MALA prompts me for a controls.ini file, which is not included in the install, nor can I find any active links to it on the internet. Anybody know if I need it, and if so, where I can find it? I was able to play Ms. Pac with the keyboard, so not sure if it is necessary (I will eventually play games with a sanwa hooked through a Hori EX2 PCB to the PC via USB).
2. I messed around with MAME UI before MALA, and was able to access all sorts of configuration options... how do I change all these options (resolution, etc.) through command line MAME (which only gives me a game list, I can't right click).
Again, sorry for the noob questions... I am just happy I have the games showing on a TV screen... that alone took weeks (and four tvs, and three graphics cards...)
BobA
  • What Me Worry?
Re: A couple MAME/MALA questions
« Reply #1 on: March 24, 2011, 03:11:31 pm »
Controls.ini link
You can use mameui as your mame executable and it should start in command line mode with mala.
« Last Edit: March 24, 2011, 06:43:03 pm by BobA »
Well Fed Games
  • Delicious!
« Reply #2 on: March 24, 2011, 04:04:08 pm »
Thank You! :cheers:
Controls.ini link
You can use mameui as your mame executable and it should start in command line mode with mal.
Hmm, did not know that, I for some reason thought it had to be command line MAME. Sweet.
clutch
  • Last login:February 06, 2014, 02:26:56 pm
« Reply #3 on: March 25, 2011, 01:11:30 am »
Just point mameui to the same ini folder that command-line mame uses.  That way, you can update the ini's with the visual interface and play them with the command line mame and mala.
Well Fed Games
  • Delicious!
« Reply #4 on: March 25, 2011, 01:34:58 am »
Perfect. Thanks!
Well Fed Games
  • Delicious!
« Reply #5 on: March 25, 2011, 03:14:16 pm »
OK, i am an idiot, I forgot about the TAB menu in-game, allowed me to adjust all the controls and screen stretch options I needed.
Can I just say, MAME and MALA are brilliant? I am constantly amazed at the depth of features. I am very much looking forward to making my own custom MALA layout to match my cab. Love it... I can see why people always build multiple MAME cabs...I am already planning more...
