Author Topic: Broke solder pad on wired 360 controller board (late), need alternate location  (Read 2283 times)
bobotech
  • Last login:November 29, 2015, 10:13:32 pm
I got my 360 board all wired up except for the 2 triggers.  It has been working fine however today I decided to add the resistors and hook up the two triggers.
The problem is that I pulled out the center pad on the right trigger when trying to put the resistor in place.  I wonder if anyone has an alternate location for that center pad?
Ugh.
SavannahLion
Can't you just follow the trace until you find a suitable location?
