Author Topic: Multi Led-Wiz Install: Need Help/advice  (Read 1978 times)
MPH
  • Last login:May 02, 2011, 09:02:33 am
« on: March 11, 2011, 09:55:43 pm »
Hoping this is an easy fix. Unfortunately, there is so little doc for the Led-Wiz that I can't figure out what is wrong.
Here's the situation:
  - 2 Led-Wiz (32) devices installed
  - Dev1 works perfectly
  - Dev2 nothing lights up (using LedWiz test program)
  - PC; WinXP SP3; plenty of power (AMD dual core CPU, plenty of RAM, etc....)
  - Led-Wiz are hooked up via powered USB
  - Led-Wiz units (both) are feeding ground to GGG RGB-LED's and couple of Paradise LED ball joysticks
  - 5v goes directly to the LEDs. Ground comes off each Led-Wiz for lighting control
  - Checked voltage at all the non-lighting LED's and it's there
  - When I manually apply ground to each contact on the Dev2 Led-Wiz, each LED lights up as it should. So they are definitely getting power.
  - USB connection only for each Led-Wiz.
  - Each Led-Wiz is wired with same format. Each is fed power from same powered USB hub.
Am I doing something wrong here?
This just doesn't make sense to me. I can manually get the LEDs on Device 2 to light, but the LED-Wiz will not do it. I've checked voltages, etc. on every point and all seems good. I am stumped. :(
Any advice or suggestions are much appreciated. :)
RandyT
  • Last login:March 31, 2026, 02:16:41 pm
    • GroovyGameGear.com
Re: Multi Led-Wiz Install: Need Help/advice
« Reply #1 on: March 11, 2011, 10:01:39 pm »
Check out Arzoo's excellent "LED-Blinky" software and make sure you select device number 2 when trying to speak to the second device.  Alternatively, I can send you a version of the test software which allows you to address device number 2.
RandyT
MPH
« Reply #2 on: March 12, 2011, 12:21:52 am »
Randy,
Thanks. I'll try that.  :)
