Author Topic: What Analog Joystick is Best?  (Read 1796 times)
goldenageofarcade
  • Last login:February 02, 2014, 04:46:46 pm
« on: March 09, 2011, 12:53:10 pm »
I'm going to build an analog stick panel for my MAME, which will be used for pre-'86 games only, so I really would prefer the stick to be traditional-looking, a ball-top would be my first choice.  I'd prefer it to be USB, but wouldn't be unwilling to by an interface for a great stick.
Can anyone recommend one that they've used?
Thanks,
Ryan
DillonFoulds
Re: What Analog Joystick is Best?
« Reply #1 on: March 09, 2011, 02:26:42 pm »
If you're going analogue, just go with a u360. Interface built in, supports buttons. If you find it's too loose, get a stronger spring, or if it's throw is too long for your tastes, circular restrictor.
VanillaGorilla
  • Coin detected in pocket
« Reply #2 on: March 09, 2011, 02:34:29 pm »
What games are important to you? That makes a big difference. You will need an interface no matter what you buy, if you are going to use a REAL arcade type stick.
goldenageofarcade
« Reply #3 on: March 09, 2011, 03:22:33 pm »
Off the top of my head, Sinistar, Food Fight, Red Baron, all 3 Star Wars, any of the hall-effect games from that era.  I definitely don't want a trigger stick, especially the ones that are molded for the right or left hand.  The Ultimarc is looking like my best bet...  I had forgotten about the fact they offer such a stick, I thought I was limited to the Happs stuff, which is all pretty pricey and the descriptions are pretty weak.  The Ultra definitely has the look I want.  I'll do some searching that one and see how people like it.
Are there any others that I should consider?
Thanks for the replies,
Ryan
VanillaGorilla
« Reply #4 on: March 10, 2011, 01:13:24 am »
I would go with the u360. I like mine, playing sinistar is aw-some!
Gray_Area
  • -Banned-
  • -Banned-
« Reply #5 on: March 12, 2011, 10:20:36 pm »
The original trigger sticks were unisex....
I argue you'd want one for Red Baron...although I swear the machine I played had a sort of dual handled yoke. Star Wars requires one.
« Last Edit: March 12, 2011, 10:22:12 pm by Gray_Area »
-Banned-
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
« Reply #6 on: March 13, 2011, 08:51:06 pm »
U360's are a great stick. They suit exactly what you ask for (old ball top) and are easy to set up to whatever you like.
