Author Topic: SOLVED (in a way): Are these indications my hard drive is going to eat it?  (Read 3313 times)
Gray_Area
  • -Banned-
  • -Banned-
I'm using XP 32bit. Most of the time, I prefer to use thumbnails in directory viewing. When I open a directory that has a lot of items in it, it can take up to thirty seconds for it to 'catch up' so that I can scroll through the whole thing. Disabling 'cache thumbnails' helps this a bit.
However. In the last day or so, opening a folder here and there has crashed that whole part of Explorer. That is, all system/data folders I have open at the time, and the task bar disappears for a little while.
Are these signs of mortality?
« Last Edit: March 12, 2011, 05:25:06 pm by Gray_Area »
-Banned-
danny_galaga
  • Last login:Yesterday at 07:41:18 am
    • dans cocktail lounge
Re: Are these indications my hard drive is going to eat it?
« Reply #1 on: March 05, 2011, 03:53:50 am »
While you are waiting for the answer, I think it would be prudent to start backing everything up  ;)
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:Yesterday at 11:59:54 am
« Reply #2 on: March 05, 2011, 09:21:34 am »
I'm not sure those are signs of impending hard drive failure so much as signs of XP failure. I.E. You may need to scan/clean/update your XP, or wipe and reload. Either of those scenarios or actual hard drive failure, or just general best practices of course, is a reason to have a regular backup in place! :)
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
smalltownguy
  • Last login:February 27, 2026, 07:59:15 pm
« Reply #3 on: March 05, 2011, 12:04:50 pm »
Do you hear any whining or clicking with the drive? Those are two tell tale signs I've observed in the past.
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
« Reply #4 on: March 07, 2011, 06:33:59 am »
Like said, the fact you're thinking about it means it should be backed up just in case.
Then defragment and see if that helps.
Bringing to life a child's imagination.
« Reply #5 on: March 07, 2011, 08:40:16 am »
I agree with Saint - probably just the OS. One thing is for sure, your hard drive WILL die eventually. Of all the hard drives I've had fail, I've only had warnings a few times, slow data transfer is the only clue I ever had of an impending failure.
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #6 on: March 07, 2011, 08:51:10 am »
+1 to the defragmenting.
A fragmented drive can cause all sorts of odd problems, several of which mimic a failing drive.
Even at that though.. Hard drives are so cheap any more, I'm getting to the point where I replace them if there is even a suggestion they might be going bad.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: March 07, 2011, 04:20:08 pm »
Run defrag with the error checking/correction. If it reports finding crossed files and bad clusters and stuff like that, you're looking at possible impending HD failure.
NO MORE!!
ark_ader
  • I glow in the dark.
« Reply #8 on: March 07, 2011, 07:01:04 pm »
Stick it in the freezer in a baggie.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #9 on: March 08, 2011, 03:09:05 pm »
This has been occuring to me, also. The drive doesn't make much noise. I do have it backed up, and partitioned so that I can easily wipe and re-install.
Hah
-Banned-
newmanfamilyvlogs
  • Last login:June 19, 2026, 12:33:17 am
« Reply #11 on: March 08, 2011, 05:46:29 pm »
Corrupted thumbnails or thumbnails with a jpeg exploit in them can crash explorer in xp.  Of course corrupted thumbnails can often occur from a thrashed hdd, so that doesn't really help you identify the problem.
If the computer is important, buy a new hdd immediately, install a FRESH copy of xp on it, install AVG anti-virus and start transferring your junk over.  Worst case scenario you've now got a spare hdd that you can use as a portable drive.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #12 on: March 12, 2011, 05:24:39 pm »
I was also having trouble with Ultramap (I couldn't edit or create maps), nor access msconfig. I was using TinyXP 11. I guess it wasn't that stable. It's not in the usual place anymore.
So, I re-installed XP Pro. I used the same TXP disc, but went for a full install. Bliss. Very snappy....though I have switched to icon view in folders to keep things that way.
I stopped using AVG a few months ago. Every time a scheduled scan time came up, the time in the box would jump an hour ahead. Basically, it wouldn't automatically scan. Since then I've been using MS Security Essentials. I like it.
-Banned-
