Author Topic: Hentarex polo 25 monitor rapid bounce  (Read 1755 times)
cadaverc
  • Last login:January 20, 2012, 12:54:02 am
« on: March 03, 2011, 12:42:41 am »
so my problem is when i start up my mame cab that has your norm in it with a hantarex polo 25 monitor in it with a J-pac and a arcadeVGA3000 the monitor has a fast bounce up and down ....more to it when i have it on the desktop.    sorry if i didn't give enough info if you need more ill try and give, im getting a capkit soon maybe that will do the trick.
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
Re: Hentarex polo 25 monitor rapid bounce
« Reply #1 on: March 04, 2011, 09:10:27 am »
What resolution are you running at? I am in the process of setting up a MAME cab and 640*480 will cause flicker and a jumpy appearance. You need a lower res to steady things out.
cadaverc
« Reply #2 on: March 04, 2011, 06:17:12 pm »
I'll try that again, I think the last time I did that the screen went crazy and had a hard time trying to get it back
cadaverc
« Reply #3 on: March 04, 2011, 11:07:08 pm »
ok found one that worked for desktop but ingame still dose the same .... little more on some games and less on some dont know how i should even truble shoot this ..or do that capkit or just buy a better monitor.
boardjunkie
« Reply #4 on: March 04, 2011, 11:40:48 pm »
I just went thru this....its not the monitor. Try running at 321x240 via quickres. Hint: make sure all your settings are where they need to be before changing the resolution. Direct draw and switch resolutions to fit must be checked. Then....you'll need a frontend/layout that will display right at that res. I used one for MaLa called "stormrider". http://www.alvarezeninternet.com/malalayout/
I'm not super crazy about how it looks, but it serves the purpose.
cadaverc
« Reply #5 on: March 05, 2011, 07:18:40 pm »
thanks again ...you guys rock, I haven't installed or did anything but what boardjunkie said led me to what i needed to read. THANK YOU  :applaud:
