Author Topic: Nestopia Display Problem  (Read 1657 times)
clutch
  • Last login:February 06, 2014, 02:26:56 pm
« on: March 02, 2011, 03:28:11 pm »
When using the Nanao 2933 monitor which is auto-switching, etc... I can plug it directly into my onboard video on my computer's motherboard and it works fine for pretty much everything.
However, when I run Nestopia, I get two images of the same screen - one on the left, one on the right.
I don't expect any Nestopia experts here, but does anyone know what causes this problem?  Is it refresh rate?  I figure there's some setting in Nestopia I need to make.  I can hook up my 19" lcd and it looks fine.
I'm running 640x480 60hz
Thanks.
clutch
Re: Nestopia Display Problem
« Reply #1 on: March 05, 2011, 06:09:41 pm »
Figured it out.  I had to uncheck the auto-set option under monitor frequency.
