Author Topic: What is this connector?  (Read 1694 times)
eclipso
  • Last login:August 21, 2018, 08:51:25 am
« on: February 27, 2011, 10:53:00 am »
I need to take out the current monitor and get it repaired however on my spare I need a connector that hooks into this however after searching for a few hours last night I cant find any information. Pic is attached. I have no idea why type of Molex that is and was a bit shocked to find out that it didnt have one.
Ken Layton
  • Guru
  • Technician
Re: What is this connector?
« Reply #1 on: February 27, 2011, 02:56:07 pm »
Tyco/AMP "Mate n lock" connector series.
eclipso
Re: What is this connector and wiring question.
« Reply #2 on: February 27, 2011, 05:02:05 pm »
Perfect, thank you Ken. I unfortunatly have another dilemma. So looking at the wiring for the current monitor (see pics) you can see the black and white connected to the purple and purple yellow. I know the green yellow is the ground but not sure how to wire the purples for the temp monitor (see second pic sorry its a bit dark) I am bit confused why it say the L and N can be switch (and have no idea what the hell the L and N stand for) as long as the ground is connected in the center?
So I am thinking I can hook the purple and purple yellow up however as long as the green yellow is obviously in the center for the ground.
« Last Edit: February 27, 2011, 05:05:04 pm by eclipso »
Kevin Mullins
    • Me on Myspace
« Reply #3 on: February 27, 2011, 08:37:27 pm »
Correct.
The purple wires can go to either of the two outside pins.
The center pin is the ground. (green wire)
The L and N could represent "Line" voltage. (your AC input)
Or it could mean Live and Neutral.....but with an isolation transformer it doesn't matter much.
eclipso
« Reply #4 on: February 27, 2011, 09:05:07 pm »
Thats what I was thinking but wanted someone with more experience with monitors to verify for me. I appreciate the response.
