Author Topic: WG K7000 top of screen sync issue  (Read 1851 times)
b3dr0ck
  • Last login:January 05, 2014, 05:49:02 pm
« on: February 26, 2011, 11:55:50 pm »
I think this is a WG 25" K7000 - I'm not exactly sure yet.  I've got to pull it out of the cab, to see. (I've got 3 other K7000s pulled out - I just want to get one working a 100%)
The color looks good, edge to edge
Contrast good
Brightness good
The issue is the top 2 inches of the screen look out of sync a little, like they are over about an inch.
I've read a post, showing the exact same symptoms - I can't find it now.
What's the diagnosis.
b3dr0ck
Re: WG K7000 top of screen sync issue
« Reply #1 on: February 27, 2011, 04:14:28 pm »
Here's an updated pic of the issue
I ran the cross hatch test, this is the results
Ken Layton
  • Guru
  • Technician
« Reply #2 on: February 27, 2011, 09:17:35 pm »
Could this post be the one you mentioned?
http://forums.arcade-museum.com/showthread.php?t=168433
b3dr0ck
« Reply #3 on: February 27, 2011, 11:00:08 pm »
Yes I believe so.
Is it your belief that adjusting the 50/60 pot and Horiz hold are the solution?
b3dr0ck
« Reply #4 on: March 04, 2011, 10:03:22 pm »
update:
I connected another Jamma to the monitor and it works fine, so I guess something is up with the jamma in the cabinet, maybe there is a setting or something, but
The monitor looks fine, the problem with the screen was with the PCB not the screen itself
