Author Topic: Illustrator 10 file saving question  (Read 2798 times)
bsoder52
  • Last login:June 24, 2025, 11:29:40 pm
« on: August 23, 2003, 02:19:54 pm »
OK,
I just called Kinkos and talked to someone.  They told me that I had to save my Illustrator 10 files a certain way for them to print.
They told me I had to "create outlines" and save in a PDF format.
Anyone know how to "create lines".  The option is greyed out when I open my files and I have no idea how to access this option.
thanks!
Bsoder52
SNAAAKE
  • -Banned-
Re:Illustrator 10 file saving question
« Reply #1 on: August 23, 2003, 02:31:42 pm »
OK,
thanks!
Bsoder52
They dont accept photoshop format ? ???
They probley do.Call again and see if they accept photoshop format.
then "export" a photoshop file from Illustrator 10 and you have it. :)
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #2 on: August 23, 2003, 08:46:46 pm »
They are talking about all the fonts you use.  If you use anytype of font in Illustrator, just highlight it and go to TYPE...CREATE OUTLINES.... and it will turn the font into shapes.  If you don't do that, then when they go to open the AI file and if they don't have the font (which in this niche artwork they probably don't), it will substitute something like courier for yours.   That's bad.
As for saving as a PDF, go to FILE...SAVE AS... and change it to PDF.  Make sure you pick Adobe 4.0 compatibility! Kinko's doesn't officially support 5.0...and can screw things up at the printer.   They really need to get with the times because now there's acrobat 6.0 out.
« Last Edit: August 23, 2003, 08:48:22 pm by Frostillicus »
