Author Topic: Kortek KTA-915 19" Horizontal Width Coil  (Read 2719 times)
gavincoolguy
  • Last login:November 03, 2011, 07:51:34 pm
« on: February 24, 2011, 02:05:30 am »
Does anyone know where the heck to get a replacement coil for the Kortek KTA-915 19" Chassis?? I have tried contacting some of the original resellers with absoluetly no luck. The coil is different then almost all pictures I see as the coil is not exposed at all. Is there a different way to adjust this coil? I am pretty sure that mine is frozen solid. I am really just looking for something I can drop in and solder in place. Thanks for any assistance in this matter, it drives me absoluetly nuts that I lose 1/2" to 1" on each side.
ps. Does anyone know if this was originally intended to be a vert monitor? It seems like the way it is set would be perfect for games but of course I am running it in a hori cab, the same cab I bought with the monitor.
gavincoolguy
Re: Kortek KTA-915 19" Horizontal Width Coil
« Reply #1 on: March 03, 2011, 12:48:22 am »
So close to Mame cabinet heaven, I may at some point swap for a lcd but I would really hate to. Do new 19" Cga's even exist anymore ?
Ken Layton
  • Guru
  • Technician
« Reply #2 on: March 03, 2011, 11:25:33 am »
Could you use an Electrohome G07 width coil? Or perhaps a Wells-Gardner K7000 width coil?
This monitor was originally made to be Horizontal Mount.
gavincoolguy
« Reply #3 on: March 03, 2011, 05:53:22 pm »
What are the deciding factors in whether I can use a coil made for another chassis ? I can see from the manual for my monitor that it has the typical 4 solder points, but it doesn't look anything like the pictures for alternatives. Mine lays flat and you cant see the ferrite core at all its covered by a plastic casing. Thanks for your reply.
