Author Topic: Strange Harness  (Read 1288 times)
stanleystar
  • Newbie
  • Last login:March 03, 2011, 03:07:12 am
Strange Harness
« on: February 18, 2011, 01:25:41 am »
Hi guys, I just bought Arcade machine inside 4 slot neo geo machine ... I disconect neo geo and I want to put there PC and connect it through jamma . There is strange harness inside I check it but for me it looks same wired as JAMMA harness ... but its quiet strange!
NR.1 - is grounding
NR. 2 - going to the TEST SWITCH
NR. 3- going to the Joystick?? ! !
Nr. 4 - going to the light on the top of the arcade machie .
So my question is connect J-PAC directly to it ? Or rewire whole system straight to the blue harness?
Thank you
Stanley :notworthy:
MonMotha
Re: Strange Harness
« Reply #1 on: February 18, 2011, 03:00:16 am »
This cabinet was originally something other than JAMMA or Neo-Geo (I don't recognize that smaller harness, but it's likely an older, pre-JAMMA vendor specific standard).  The adapter board that's there makes it the slightly modified JAMMA that's used by Neo-Geo 4 slot motherboards.  It also appears to be numbered backwards!
The cabinet probably lacked a test button, so it was added in, hence the stray wire, and they needed a ground for it, hence the stray ground wire.
The red wire probably goes to the Neo-Geo game select button as that's the position it's in.
The big yellow wire is in the position for a speaker, which would probably run up to an area near the marquee.
The JPAC should generally be compatible with the alternate Neo-Geo wiring as it doesn't move much around (mostly audio, which the JPAC doesn't do anyway, and coin/test, which the JPAC doesn't do either).  However, again, your harness appears to be numbered backwards, so confirm that before you plug anything in and then account for it when making connections.
