Author Topic: Philco Touchscreen Jukebox  (Read 4131 times)
bogielocks
  • Last login:October 18, 2014, 11:17:18 pm
« on: February 08, 2011, 02:12:55 am »
Greetings All..
I've been lurking around this site for years, but finally decided to join. I've recently picked up a working Philco 38-4 antique radio. I know some folks may get mad redesigning such a nice piece of vintage electronics. I looked for an old radio cab so I wouldn't feel so guilty, but everything I found was too expensive ($200 plus). I found this radio two towns over for $50, and the cabinet is in great shape, just needs very little cleaning. The chassis, tubes and the dial I'm planning on giving to a radio restorer. That way some of this classy machine may bring back another vintage radio.
I just couldn't pass it up. I have a 15" touchscreen that will fit perfectly in the center, you can almost see where I mean. I hope to use two of the three original knobs for power and volume. I'll just install them in different locations. There's no way I can do anything until the spring since I have no indoor place to work. I will post an update once I get started. Anybody who has any ideas, I'd welcome anything..
Cheers!
Bogie
« Last Edit: February 08, 2011, 02:14:52 am by bogielocks »
Re: Philco Touchscreen Jukebox
« Reply #1 on: February 08, 2011, 07:40:12 am »
Fantastic. I've been on the lookout for a unit like that. Busted enough to not be worth trying to restore, but decent enough that with a little work, you could retrofit a nice touchscreen in it.
Good score.
Can't wait to see where you go with it!
Bobby115
  • Last login:July 18, 2011, 06:55:13 pm
« Reply #2 on: July 17, 2011, 05:54:14 pm »
Here is one i did a while back.............
Meph
  • Last login:December 12, 2024, 02:00:40 am
« Reply #3 on: July 17, 2011, 07:09:17 pm »
http://forum.arcadecontrols.com/index.php?topic=112421.0
Here is the project thread for the Philco i'm currently working on.  I actually got back to work on it again today and its fully stripped and ready for lacquer now.  If your planning to use a 15" Elo touchscreen in it then you won't have enough room to keep those two dials if you mount it on the front slope.  If your planning to use software like E-Touch then you really wont need the dials anyways.  The radio your using has the same speaker cloth as mine.  I have a site that sells the philco "V" pattern cloth that ours uses if you want a link.  I think its about $30 for the replacement.  Judging by that photo it doesn't look like you will need any real restoration work on the cabinet so it should be a pretty easy project.  Grats, I love seeing more people doing these projects, gives me more ideas for mine.  =)
