Author Topic: Ok to route acrylic?  (Read 4436 times)
codenamed
  • Last login:January 06, 2012, 12:46:04 pm
« on: February 05, 2011, 11:56:44 am »
I'm in the process of a conversion and need a new cp cover. I went to home depot and a sheet of lexan is 60 dollars where as acrylic is 20 I'm on a budget so I was wondering if acrylic is easily routable or if its just gonna snap if I try?
orchidius
  • Last login:January 30, 2013, 12:44:11 pm
Re: Ok to route acrylic?
« Reply #1 on: February 05, 2011, 02:00:34 pm »
I think all of those plastics are easily routable... Anyways, if acrylic is the same as plexiglass, routing is basically the only way to go :p.
codenamed
« Reply #2 on: February 05, 2011, 04:39:52 pm »
Good to know I love routing with my flush trim bit ;-p
r32
  • Last login:December 18, 2011, 05:44:28 pm
« Reply #3 on: February 06, 2011, 01:17:33 pm »
Yes, you can definitely cut acrylic with a router.
Be careful of heat buildup though and look for router bits made specifically for cutting plastics.
Here is some more information:
http://www.cnczone.com/forums/woodworking/51513-cutting_acrylic_wood_router.html
You can talk to these guys too. They actually sell sheets and will do perfect laser cuts for cheap. It's where I get my material from and they are great to work with.
http://www.tapplastics.com
dawolv
  • Last login:March 25, 2016, 08:23:21 am
« Reply #4 on: February 08, 2011, 09:00:29 am »
I just routed my Plexi so it is definately routable and it makes "Snow" hehe  ;D
