Author Topic: Issue with Opti-pac mouse button inputs  (Read 2083 times)
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« on: August 20, 2003, 02:09:47 pm »
I have an "issue" with the mouse button functionality of my Opti-pac.
First the setup:
AMD XP1800 with 512 MB of DDR.
Windows 98SE.
MAME AMD K6 DOS version from several versions ago compiled to remove the "OK" screens.
Opti-pac with USB.
DOS USB is enabled in the BIOS.
Now to the issue.  The mouse button functionality of the Opti-pac works perfectly in Windows.  Every time I click one of the two buttons on my control panel allocated to the mouse buttons, they respond.
However, when I run MAME and get into a game, I can click those same buttons, and they will only register a click about 60% of the time.  As you might imagine, that hampers one's score quite a bit.   ;)  The odd thing is, I would expect the trackball to have the same problems if it was a DOS USB issue, but the trackball works flawlessly.
Has anybody else experienced this?  I wanted to see if there was a work around other than upgrading to the Windows command line version of MAME, but if not, that's what I'll do.
<edit>  I have now tried with the Windows command line version of MAME and have the same issue with that.  So the DOS theory is out.
Thanks.
« Last Edit: August 20, 2003, 07:07:10 pm by RacerX »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Issue with Opti-pac mouse button inputs
« Reply #1 on: August 20, 2003, 05:17:57 pm »
Ask ultimarc
RacerX
« Reply #2 on: August 20, 2003, 05:59:18 pm »
Ask ultimarc
He's on vacation until September 6.  In the meantime, I thought I would run it by you guys.
