Author Topic: Daphne Games on a TV  (Read 3383 times)
buck3480
  • Last login:August 28, 2007, 03:41:14 pm
  • I'm a newbie
« on: August 20, 2003, 11:04:29 am »
I hope this hasn't been asked recently.  I did a seach, but nothing came up after a quick glance thru.  I actually have 2 questions.  First, I have a ATI Radeon 64 Card, AGP 4X on a Windows XP machine.  I'm using the S-video out port and going into an RF Converter to connect all this thru coax to the TV in my Arcade.  The resolution for the TV (set by the video card) is 800X600 at 60Hz.  I also have a computer monitor connected to the machine at the moment so I can make sure that there is a picture coming out of the card, and so I can see the text in Windows to set stuff up.  Well, I can see and play the Daphne games on the monitor, but I don't get a picture on the TV.  BTW, all the Mame games and PC things work on the TV and the monitor at the same time, it's just the Daphne stuff giving me problems.   So, what could be causing the Daphne stuff to not show up on the TV?  I'm guessing it has something to do with the refresh rate, but I'm not sure.
Second question...how much better would the picture be if I bought another TV that took S-video input instead of going through the RF converter into coax?
Thanks for your time guys.
buck3480
  • I'm a newbie
Re:Daphne Games on a TV
« Reply #1 on: August 21, 2003, 11:19:16 am »
I got it figured out.  I found out that when I play any type of video (AVI, MPEG) it wasn't playing on the TV.  Once I noticed that, I knew it was something with the card.  There's an option in the software that keeps video from going to the TV.  Once I set that, it started working.  Thanks.
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #2 on: August 22, 2003, 12:28:43 pm »
good to know for future reference. thanks!
skorch
  • Last login:October 26, 2005, 10:58:03 pm
  • Go ahead............make my cab.
« Reply #3 on: August 23, 2003, 05:12:32 pm »
Daphne is the Dragon's Lair emu right? So how does it look on the set?
"The only problem you've got sheriff is a short supply of guts!" - The Stranger
StephenH
« Reply #4 on: August 30, 2003, 03:43:42 pm »
Try running at 640x480 or 720x480 with an INTERLACED MPEG.  Since TVs are interlaced, and the original game was interlaced, you should make sure your MPEG is interlaced.
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #5 on: August 31, 2003, 09:52:58 am »
I know that when I used the DVD2Daphne utility with the DVD ROM version of DL, I got interlaced video.  Kind of annoying to watch but too lazy to go in and work with them.  Would look good on a TV I bet.
thecount
  • Last login:March 29, 2004, 09:19:24 am
« Reply #6 on: September 23, 2003, 09:24:19 am »
I have the same setup and am also wondering if I should get a TV with an direct s-video input. Did you get one and is it better? Also do you have problems with blurry text in windows mode, but when you run the games they work fine?
DaveMMR
« Reply #7 on: September 23, 2003, 10:37:00 pm »
Yes S-Video is always better than the RF converter into a Coax (haven't really seen Composite, though it's supposed to be even better).
