Author Topic: Newbie with Rockola 474 problems  (Read 6436 times)
USS DADDY
  • Last login:January 21, 2012, 11:39:50 pm
« on: January 25, 2011, 09:55:35 pm »
Hi and hope someone can help with our gameroom juke.
Side 2 selections trip the internal ckt brkr after the record is fully on the turntable.  Side 1 selections work normal.
When side 2 trips, I have to disconnect the selector harness which makes the "scan" switch work to place back the side 2 selection.
Then reconnect the harness and place switch to "on" for side 1 selections only.
Any advice is greatly appreciated, thanx!
Ken Layton
  • Guru
  • Technician
Re: Newbie with Rockola 474 problems
« Reply #1 on: January 25, 2011, 11:08:47 pm »
The "A-B Snap Switch" is probably bad internally. Replace it with a new one. Get the part number from your manual and order from www.victoryglass.com
USS DADDY
« Reply #2 on: January 27, 2011, 03:29:42 pm »
Found it on the print and machine.
Thanx a lot, Ken!
USS DADDY
« Reply #3 on: February 14, 2011, 01:16:39 pm »
It s not the A-B snap switch...machine is still making the play relay contacts "dance" when side 2 is selected, then the internal c.b.trips.
Any other help would be appreciated, thanx, Eddie.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: February 14, 2011, 02:40:32 pm »
Suggest hopping over to the jukebox forum at www.phonoland.com and making a post there.
