Author Topic: Need Help changing the Welcome and Shutdown Screens on Win XP  (Read 1830 times)
Hituro
  • Last login:September 04, 2016, 01:12:43 am
« on: January 22, 2011, 03:58:38 am »
Does anyone know a safe and easy way to get this done?  I basically want to hide the windows welcome and shutdown screens with my own theme for my arcade cab.  I was able to change the windows loading screen using BootSkin, but I still need to change those other screens, and I'm just worried about messing stuff up if I hack the files.  Anyone have any suggestions?
JohnEDollar
  • Last login:December 29, 2015, 06:36:55 pm
  • Keep it Smooth...
Re: Need Help changing the Welcome and Shutdown Screens on Win XP
« Reply #1 on: January 22, 2011, 02:23:08 pm »
Hituro:
Be sure to check out the BYOAC Wiki on this subject:  http://wiki.arcadecontrols.com/wiki/Hiding_Windows
(Excellent resource!!!)
- John
haplo
« Reply #2 on: January 23, 2011, 01:44:41 am »
In my case I use X10 devices. Specifically the USB Firecracker (CM19a) and Wireless Transceiver (TM751). I originally had these for normal home use (turning lights on and off), but later found out by accident I could use it to hide windows startup/shutdown screens.
I hook the CM19a to my cabinet's PC and the TM751 to my monitor's power cable. The Firecracker comes with a command line software tool that allows me to control the TM751. I have it so the computer turns on the monitor after it loads everything and it's ready to rock. I also have the PC turn off the monitor's power at shutdown, just before showing the "shutting down" screen. I achieve the triggering of these commands with a free tool called Xecutor. This way I don't have to hack anything in windows. It doesn't cost a lot either (about $20 USD). There are other cabinet related uses for this approach as well.
Hituro
« Reply #3 on: January 23, 2011, 03:05:53 am »
Thanks for this info!  I will definitely try some of this stuff out :)  Now if only I can get Sega Model2 Emulator to use 2 Light guns I'd be set :P  Also need to play with Autokey program so I can hide some of those menus for loading certain PC games like HOD2 and 3, and I'll be all set :)
