Author Topic: wells gardner  (Read 4028 times)
stone wall
  • Last login:March 06, 2015, 07:54:05 am
wells gardner
« on: January 19, 2011, 01:31:26 pm »
Hi I have a wells gardner 25k7193 I fliped it from horizontal to vertical now the colors are messed up any one ever seen this or now how to fix it?Thanks
Re: wells gardner
« Reply #1 on: January 19, 2011, 01:31:58 pm »
You just need to degauss, that's all.
stone wall
Re: wells gardner
« Reply #2 on: January 19, 2011, 01:33:31 pm »
how do you do that?
Re: wells gardner
« Reply #3 on: January 19, 2011, 01:37:38 pm »
With that monitor, I think if you power it off for ~20 minutes, and turn it back on, it should do it automatically...
stone wall
Re: wells gardner
« Reply #4 on: January 19, 2011, 02:35:59 pm »
I tried that same thing even if I rotate it 360 it does the same the only way its good is in the horizontal but I got a 60 in 1 board that calls for it to be in the vertical very strange
Re: wells gardner
« Reply #5 on: January 19, 2011, 02:38:58 pm »
You have unshielded speakers nearby?
stone wall
Re: wells gardner
« Reply #6 on: January 19, 2011, 02:40:50 pm »
yes I pulled the speaker right out I even pulled the monitor out of the cab and it still does it
WhereEaglesDare
    • My HomePage
Re: wells gardner
« Reply #7 on: January 19, 2011, 04:21:07 pm »
you should have a degausing coil on the tube, it looks like a thick white cable just tied up around the tube, make sure that is connected to something, if it is disconnected take pictures
stone wall
Re: wells gardner
« Reply #8 on: January 21, 2011, 03:20:59 pm »
here are some pic
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: wells gardner
« Reply #9 on: January 21, 2011, 11:20:34 pm »
borrow/buy/MAKE a manual deguassing coil .
 such as : http://www.mcmelectronics.com/product/72-785&CAWELAID=240983086  ( yes, its ok for larger tubes )
the field produced by the internal coil usually isn't strong enough to correct an orientation shift.
stone wall
Re: wells gardner
« Reply #10 on: January 29, 2011, 09:10:13 am »
OK i got a degaussing coil it did some clearing up but their is still some discolor at the bottom of the screen I did it several times with the same effect am I missing something?
qrz
Re: wells gardner
« Reply #11 on: January 29, 2011, 12:05:03 pm »
u may need to open the back to get at the monitor frame.
several passes may be needed .
residual magnetism can be a factor when the field is stong enough.
years ago , i had a TV that i thought would never deguass. was just about to resort to adding magnets.
decided to hit every square centimeter i could reach. that did it .
problem was caused by a near direct hit of lightning . gotta love the EMP  :-\
mgb
  • Last login:June 05, 2026, 10:45:08 pm
  • North East, US
Re: wells gardner
« Reply #12 on: January 29, 2011, 11:50:35 pm »
Sometimes you need to deguass a couple of times.
remember that you start making small circles close to the screen and as you move away from the screen, make larger circles.
stone wall
Re: wells gardner
« Reply #13 on: February 06, 2011, 08:56:41 am »
OK Its fixed what I did was I had an old magnet from a speaker I placed it at the lower corner of the monitor where the colors were off left it their for a day or so then removed it and used the degaussing coil again that did it looks awesome Thanks to everyone who tyred to help me out
mgb
  • North East, US
Re: wells gardner
« Reply #14 on: February 06, 2011, 04:21:50 pm »
I'm glad to hear it worked out Ok.
Be careful when using a permanent magnet for degaussing. I've never tried it but I hear it is easy to cause permanent problems.
I use a bulk tape eraser and it works great.
