Author Topic: Mala for the Game List after Hibernate (using Hardware for LED's)  (Read 4352 times)
Blackus
  • Last login:April 22, 2011, 03:15:58 pm
Hi
I have some problems with mala: first of all, sliding between the lists it always happens that it does not find the games of a list and often it goes in crash (es: Game list xxxx or "Error reading Gamelist xxxx" )
Then I would want to know if there is a way in order to start plugin (es. the Mala-Wiz) also when it is returned from the state of ibernazione (Currently set off solo during a normal start).
thanks
« Last Edit: January 19, 2011, 12:54:37 am by loadman »
Blackus
Re: Crash Mala for the Game List
« Reply #1 on: January 15, 2011, 04:03:01 pm »
if I insist on the same one game list crashata me exits an error and the warning of creation of log files
The  problem is the mala with the mala-wiz. When it returns from the Hibernate, something does not go and the game lists crash :(
 can someone fix it?
« Last Edit: January 15, 2011, 04:49:55 pm by Blackus »
loadman
  • Moderator
  • Last login:June 16, 2026, 05:29:13 pm
  • MaLa FE developer
    • MaLa
« Reply #2 on: January 15, 2011, 06:12:38 pm »
Please?  ???
Does it work OK when not using hibernate?
ie Does it work when using suspend?
I must admit I've never tested/used hardware with suspend or hibernate.
Can you set you logging to debug and send me a full log please?
« Last Edit: January 15, 2011, 06:23:52 pm by loadman »
Blackus
« Reply #3 on: January 15, 2011, 06:40:27 pm »
Please?  ???
So...
when not using hibernate Mala work..
if i using the hibernate the gamelist crashes when i I slide the lists.
If i using the normal boot the gamelists don't crashes (and not even mala)
If using the hibernate but deleting the plugin mala-wiz don't crash.
The Log file is the full Log (I have sent so as it was in the folder, I have not modified it)
help :(
loadman
  • Moderator
  • MaLa FE developer
    • MaLa
« Reply #4 on: January 15, 2011, 06:59:35 pm »
Thanks.   I am sure you meant 'Help Please' right ?  ;)
I want you to change the settings in MaLa so it saves more detail in the log.
On the options windows - Credits. Help and Logging. There is a drop down menu on the bottom right of the screen.
Please set that to DeBug.
Then run mala until it crashes in all scenarios you described.
Then please pass the full log
Blackus
Re: Crash Mala for the Game List after Hibernate (using Hardware for LED's)
« Reply #5 on: January 18, 2011, 07:22:10 pm »
after two format of disk, the problem more has not appared. If it had to still happen, I reactivate the modality debug and I send to you all.
 For now... Thank you for your time :)
Blackus
Re: Mala for the Game List after Hibernate (using Hardware for LED's)
« Reply #6 on: January 19, 2011, 05:26:34 am »
since they are here, I wask if it is even possible to make so that returning from the hibernate, the plugin are activated or reboot, because now the led-wiz they off when return from the hibernate
PaTrYcK
  • Last login:May 02, 2020, 05:22:19 am
« Reply #7 on: January 19, 2011, 06:45:02 am »
Your problem could be caused because your usb-hardware after hibernation / standby not wake up ,try:
control panel-system-hardware-device manager-controller usb
There are some USB root hub:
In each "Hub root hub" select properties and then go to power management, uncheck "Allow the computer to turn off this device to save power":
Restart PC!
« Last Edit: January 19, 2011, 07:02:35 am by PaTrYcK »
