Author Topic: Creating a Transparent Marquee  (Read 4846 times)
nintendoid
  • Last login:March 16, 2026, 03:18:46 pm
    • Nintendoid
« on: January 09, 2011, 06:46:57 am »
Just a little help or if it is even possible...
Ive created my own marquee for some games there .png/.gif with a transparent bg.
However in mala when they load it add a white bg to the logos.. is there anyway I can remove the bg color from mala frontend/layout?
help as always appreciated  :notworthy:
loadman
  • Moderator
  • Last login:June 16, 2026, 05:29:13 pm
  • MaLa FE developer
    • MaLa
Re: Creating a Transparent Marquee
« Reply #1 on: January 09, 2011, 04:35:14 pm »
ehhh Weird.
Can you send me a screen shot and an example Marquee please
nintendoid
    • Nintendoid
« Reply #2 on: January 09, 2011, 04:43:24 pm »
please find attached the image file...
as you can see this is a clear.png but the bg is displayed as white.
loadman
  • Moderator
  • MaLa FE developer
    • MaLa
« Reply #3 on: January 09, 2011, 06:14:58 pm »
Hi,
I see the screenshot tat highlights the problem (thanks) but no marquee file is attached for me to test with.
You may have to zip it first?
nintendoid
    • Nintendoid
« Reply #4 on: January 11, 2011, 05:00:53 pm »
pm'd you a copy of the png.... any joy?
loadman
  • Moderator
  • MaLa FE developer
    • MaLa
« Reply #5 on: January 11, 2011, 05:36:02 pm »
Hey I got that.
Have not had a chance to check yet?  Real life gets in the way some times :-(
nintendoid
    • Nintendoid
« Reply #6 on: January 14, 2011, 08:04:15 am »
Hey I got that.
Yeah not a problem... know how that feels :)
yeah if you get a chance that would be great :)
loadman
  • Moderator
  • MaLa FE developer
    • MaLa
« Reply #7 on: January 15, 2011, 06:20:37 pm »
Looking at this issue now
loadman
  • Moderator
  • MaLa FE developer
    • MaLa
« Reply #8 on: January 15, 2011, 07:03:53 pm »
Have you ticked the Transparent box on the layout editor?
If you do you would get similar results to attached picture.
I had a look there are lines on part of the graphic.  See Attached screen shot
It is just not visible to the naked eye so easily.
Mala uses the bottom left pixel as a colour reference.
Those lines are part of the graphic, but just a slightly different colour.
You should be able to see/remove them with a decent graphics editor.
This isn't a MaLa issue.
« Last Edit: January 15, 2011, 07:07:04 pm by loadman »
