Author Topic: Problems with LEDBlinky Pause Animations  (Read 1720 times)
markronz
  • Game on!
« on: January 07, 2011, 03:54:00 pm »
OK, so I'm totally confused what happened because this WAS working perfectly fine before.   I'm not sure what I changed exactly, but when I pause MAME, LEDBlinky no longer does a Random Montage of animations any more.   As you can see in my attached screen shot, I do have it set to be enabled.
I wasn't really sure where to start on this, so I figured I would just attach a zip file with all my LEDBlinky INI files in it.   Can anyone help me figure out why it's no longer doing that sexy dance when I pause it?
Let me know if you need anything else to help me figure this out!  Thanks!
arzoo
  • Last login:July 05, 2026, 11:11:48 pm
  • Robots WILL kill you.
    • LEDBlinky
Re: Problems with LEDBlinky Pause Animations
« Reply #1 on: January 09, 2011, 11:26:03 am »
This is a bug with version 4.0 which has been fixed in 5.0. Or you can check the "Flash Player Start with Credits" option and that will also solve the problem.
Robots will kill you.
Arcade Addiction
markronz
  • Game on!
« Reply #2 on: January 09, 2011, 12:19:57 pm »
Oh yeah!  That's what I changed, now I remember!   If I download the new version I can just copy the new EXEs into that same folder and still use all my same ini files right?  I don't have to re-set everything up again, right?
arzoo
    • LEDBlinky
« Reply #3 on: January 09, 2011, 12:30:38 pm »
Unzip the upgrade files into the folder above \LEDBlinky and let it overwrite any existing files. Then run the config app one time to complete the upgrade - you won't have to change any of your settings or ini files.
Arcade Addiction
markronz
  • Game on!
« Reply #4 on: January 09, 2011, 01:09:42 pm »
That fixed it.  Thanks so much for the help!
