Author Topic: Another Info Window Related Bug (resolved)  (Read 6545 times)
markronz
  • Game on!
« on: January 07, 2011, 10:55:22 am »
I think you added a fifth Definable object for MAME a while back in Mala.  However, if I go to the Info Window tab and look in the Image Type drop down box, there is no Definable 5 there.  See the attached screen shots to see what I mean.
« Last Edit: January 08, 2011, 04:40:47 pm by loadman »
loadman
  • Moderator
  • Last login:September 12, 2026, 04:03:50 am
  • MaLa FE developer
    • MaLa
Re: Another Info Window Related Bug
« Reply #1 on: January 07, 2011, 06:25:43 pm »
Oh Yeah!
Easy Fix.
Thanks for reporting.  :applaud:
Will be in next Beta
danny_galaga
  • Last login:Today at 07:40:47 am
    • dans cocktail lounge
« Reply #2 on: January 08, 2011, 03:08:42 am »
Just looking at that screen shot. I've been trying to set up the info screen the same as in that example. Set up like that, what are you hoping to happen? Just trying to work out if I'm not understanding what its supposed to do, or if there's a bug...
loadman
  • Moderator
  • MaLa FE developer
    • MaLa
« Reply #3 on: January 08, 2011, 04:51:31 am »
Oh Yeah!
Easy Fix.
Download the latest beta here (link under the release version) :
http://www.malafe.net/index.php?page=download
markronz
  • Game on!
« Reply #4 on: January 08, 2011, 10:22:55 am »
well there's an info button in Mala. When you press it, it shows you the various different items of information about the game you currently have highlighted.
In the first screenshot, it just shows my MAME settings, where it points to all the various folders.
The second screenshot, it shows the configuration of the Info window.   The bug I reported was just that the 5th definable object was missing as an option.  But this screen just allows you to control what comes up and in what order when you press the Info button.
I'm not sure exactly what you were looking for in terms of an answer, but if you have more questions let me know!
Oh Yeah!
Easy Fix.
Testing this and the other bugs out now loadman, I will let you know how it turns out!
markronz
  • Game on!
« Reply #5 on: January 08, 2011, 10:32:43 am »
Definable 5 is there now.  Works great!  Thanks loadman!
Triangel7D
  • Last login:September 10, 2017, 01:06:09 pm
« Reply #6 on: January 08, 2011, 10:37:31 am »
Markronz,
I'm curious -- What are infoCards? I've never come across them in gathering Mame extras.
markronz
  • Game on!
« Reply #7 on: January 08, 2011, 10:40:00 am »
Oh.   :)   I exported all the control panel pictures from CPWizard.  So those are just my pictures that tell me what my individual controls do.   I couldn't think of what else to call those pictures.   I also have the original factory control panel pictures on the Info menu, so I didn't know what to refer to these CPWizard ones as.
Triangel7D
« Reply #8 on: January 08, 2011, 03:01:05 pm »
I've never heard of CPWizard! It sounds cool. I'll have to give it a try. Thanks!
markronz
  • Game on!
« Reply #9 on: January 08, 2011, 03:16:14 pm »
Yeah check it out!  You can set it up to work when you pause MAME too.  Or to replace the info page in MaLa.  It's pretty cool if you can get it to work.  I have troubles getting it to work right personally.   But even still, you can export the images, so that's what I did.   Anyway, end sales pitch, it's definitely worth checking out.
Triangel7D
« Reply #10 on: January 08, 2011, 03:38:19 pm »
I'll definitely use it to export the cp images at the very least!
danny_galaga
« Reply #11 on: January 14, 2011, 07:52:55 am »
Yeah, I knew about that. What I wanted to do is use the Info function to show general info pertaining to the cab operation. This is universal info that isn't different for each game. Things like: To browse menu, use joystick up/down.
Turns out it's not set up that way. I found a crude way around it though:
http://forum.arcadecontrols.com/index.php?topic=108223.msg1150934#msg1150934
markronz
  • Game on!
Re: Another Info Window Related Bug (resolved)
« Reply #12 on: January 14, 2011, 09:43:56 am »
That makes sense.   Sucks you had to do a manual rename though.   It should be possible to write a script to do that sort of thing and eliminate the leg work.  Glad you got er done one way or another though.
danny_galaga
« Reply #13 on: January 14, 2011, 08:16:22 pm »
It would easily be possible for someone who knew what they were doing :duckhunt
