Author Topic: Is there an alternative to Volume Tray?  (Read 1965 times)
bgmagic
  • Last login:January 14, 2014, 11:13:53 pm
« on: January 03, 2011, 11:58:47 am »
Hi all,
I'm currently using Volume Tray in my cabinet to increase and decrease the volume (usually while in a game).  When I made my graphic overlay for my control panel. I intended for there to be one button called "volume" (mapped to the letter "V") that if I held it down I could press UP or DOWN on the joystick to raise or lower the volume.  Problem is that Volume Tray only supports certain hotkeys (CTRL-ALT-SHIFT and a keystroke).  Temporarily I have it setup that if you hold down CTRL & SHIFT you can push up or down to control the volume.  Is there another way to be able to control the volume with holding down my one volume button and pushing UP or DOWN on the joystick?  Everything is hooked up to an ipac 2 in my situation.
Thanks!!
Gray_Area
  • -Banned-
  • -Banned-
Re: Is there an alternative to Volume Tray?
« Reply #1 on: January 03, 2011, 08:07:38 pm »
Look up 'cabvol'.
-Banned-
bgmagic
« Reply #2 on: January 03, 2011, 09:16:24 pm »
It appears that this will work.  Thanks a lot!!!!
headkaze
  • 0x2b|~0x2b?
« Reply #3 on: January 03, 2011, 09:28:54 pm »
I always recommend people check out the BYOAC Wiki Utilities page. I've been adding all sorts of utils to that page for years.
