Author Topic: K4600 vertical Collapse after incorrect of B and G yoke connections  (Read 2746 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
After I incorrectly connected the B and G connections on the yoke there was load buzzing sound and no picture when I turned the game (gorf) on. On correction now an expereincing vertical collapse of the display (a single horizonta line)
Any ideas on what is cause?
Did i fry any components or the kill the yoke/tube itself?
Any suggestions on where i should start looking?
is this monitor now officially dead?
Ken Layton
  • Guru
  • Technician
Re: K4600 vertical Collapse after incorrect of B and G yoke connections
« Reply #1 on: December 30, 2010, 11:42:31 pm »
Probably damaged the transistors on the hor/ver (a.k.a. the "XY" ) card.
rchadd
  • Made in Cornwall
« Reply #2 on: December 31, 2010, 03:35:40 pm »
thanks ken.
i will check out the schematics and order some new transistors.
any suggestions on specific transistor(s) that could be responsible?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: January 01, 2011, 01:01:51 am »
The two heat sinked transistors on the hor/ver board.
rchadd
  • Made in Cornwall
« Reply #4 on: January 01, 2011, 09:33:56 pm »
i guess those would be the transistors labelled V.OUT with doted circle around them on the schema? TR305 & TR306
would i also need to look at possibly replacing other V. transisitors? V.AMP or V.DRIVE?
unfortunately i do not have the monitor chassis local to me to verify the component naming.
rchadd
  • Made in Cornwall
Thanks for the advice Ken i have fixed the vertical collapse issue.
I tested the transistors using multimeter in diode test mode and it confirmed that tr305 and tr306 were bad.
the schema indicated that following codes for the transistors:
tr305   2SA490
tr306   2SC1625
I used a TIP31 instead of a 2SC1625 as i could not find supplier in UK.
