Author Topic: LED Blinky info  (Read 2530 times)
Garza
  • Last login:July 09, 2015, 10:53:29 am
LED Blinky info
« on: December 17, 2010, 08:06:01 pm »
Ok I know this is probably an easy question so bear with me  :cry: Where would you find the default ini file to put into the led blinky info.  :dunno I am using Maximus Arcade. It sounds as if it should be in there somewhere but I cannot find it there or if its in LED Blinky itself. Also if anyone could advise me what folder in Maximus Arcade would be the Color exe for LED Blinky. I have everything else working lights up on the test and when I press a button all the buttons light up at the same time which makes me believe that might not be correct either... :banghead: Please help driving me crazy!
Garza
Re: LED Blinky info
« Reply #1 on: December 17, 2010, 08:20:59 pm »
This is what the error page reads, missing path to Maximus Arcade default.ini file and also missing value in settngs.ini : mame controls file  :timebomb:
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Re: LED Blinky info
« Reply #2 on: December 18, 2010, 06:53:17 pm »
Find the MA default .ini file here:
..\Maximus Arcade\Frontend\preferences
You'll need to download control.ini (mame controls file) - see this support thread for links:
http://www.dndw.com/ledblinky/Support.htm#ControlsINI
Not sure what you're referring to with "colors.exe"?
Robots will kill you.
Arcade Addiction
Garza
Re: LED Blinky info
« Reply #3 on: December 21, 2010, 11:01:11 pm »
Im Sorry what I wanted to say is colors.ini file where and what is that? Thanks for the reply!
arzoo
    • LEDBlinky
Re: LED Blinky info
« Reply #4 on: December 22, 2010, 09:17:07 am »
The colors.ini is included with the LEDBlinky install - it's in the /ledblinky folder.
Arcade Addiction
