Author Topic: HELP...Looking for a tutorial on how to install Betson/Imperial Trackball...  (Read 1040 times)
sirhcman
  • Last login:January 20, 2008, 01:50:45 pm
Looking to do this without a mounting plate, I did some searches of the board but wasnt too successful. I heard that you dont need a mountin kit but I was curious if someone documented how to install one without it because I am very perplexed on how it would even be possible. Any help is appreciated :)
THANKS
CHRIS
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Well the mounting plate is the esaiest most straightforward way....
here's how eightbit did it
Basically you cut out the football shape to a tight fit and create some sort of support underneath to support the tball... Then cover the top with artwork/vinyl/contact paper (well look at the link w/picture instead of my rambling explanation)
I'd strongly recommend using a mounting plate if you want an "easy" way to do it... but there's some excellent pics of how others have done it sans mounting plate =)
good luck!
Rampy
« Last Edit: August 16, 2003, 05:34:31 pm by rampy »
