Author Topic: How do you have a trackball and spinner at the same time?  (Read 1569 times)
Richy
  • Last login:September 15, 2004, 09:04:53 am
« on: August 15, 2003, 10:17:30 pm »
See subject.
If they both use mouse inputs, how do you have both of them?
Do you have to plug them in and out?
Zeitgeist
  • Last login:June 05, 2013, 05:57:51 pm
Re:How do you have a trackball and spinner at the same time?
« Reply #1 on: August 15, 2003, 11:09:16 pm »
Windows & dos supports multiple mice.
You can have one PS2 & two serial & several usb if you like.
They will all operate at the same time but they all control the same cursor.
So if you spin the Tb in one direction & the spinner in another, the cursor will simply jitter & then go in one direction when the other input stops spinning.
Right now I have three different pointing devices attached to my PC.
A usb cordless mouse, a PS2 imperial trackball, & a usb optical mouse, & sometimes I attach a serial spinner.
Makes sense???
As far as having two seperate TBs & have them operated independantly in mame, I think that Analog Mame may support this but I'm not sure how.
Good luck!
« Last Edit: August 15, 2003, 11:12:15 pm by Zeitgeist »
There is a theory which states that if ever anyone discovers what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.
hooded_paladin
  • Last login:November 06, 2013, 08:59:01 pm
  • Finch! hahaha
« Reply #2 on: August 15, 2003, 11:09:34 pm »
either you have a switch that will turn on/off a trackball and spinner attached to the same mouse hack (http://www.oscarcontrols.com/DPDTswitch.shtml), or they're two different usb mice and you have Win 98/Me.
If you're talking about USING both as input at the same time, you'd have to have two seperate USB devices.  You can have two spinners at the same time easily, because they each only use one axis of the mouse.
There is SO a spoon.
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #3 on: August 16, 2003, 03:57:13 am »
If you use and Opti-pac (www.ultimarc.com), you can hook both up together and the board will use whichever one you touch first and ignore the other.  So if you spin the TB and then spin the spinner, it will ignore the spinner since the TB was touched first.  This would seem to be the way you would want it to work since I can't think of a game where you would use both at the same time on purpose.
:) Rotate or die! :)
Richy
« Reply #4 on: August 16, 2003, 06:12:53 am »
Ok, thanks.
SirPeale
  • Green Mountain Man
« Reply #5 on: August 16, 2003, 10:01:55 am »
There is some DOS support for USB.  I posted in the software forums a couple weeks ago about it.
