Author Topic: Red Line on Laptop LCD  (Read 1892 times)
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« on: December 08, 2010, 01:00:48 am »
I have red vertical line on the LCD of a Dell E1505.
Is this most likely a bad LCD itself or the electronics that drive the LCD?
I have replaced the top cover and LCD bezel before so I am comfortable in ordering and installing a replacement LCD but I don't want to go down that path if the issue is not the LCD itself.
I look forward to any and all replies.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Red Line on Laptop LCD
« Reply #1 on: December 09, 2010, 10:20:57 pm »
ribbon cables and connectors are a common fault on lcd panels
MonMotha
« Reply #2 on: December 10, 2010, 12:43:48 am »
This particular fault usually is a result of a bad connection between all the interface boards (integral to the LCD panel assembly and not replaceable) and the LCD matrix itself.  There are a whole bunch of adhesive-made connections along the LCD edge.  If one of these connections fails, you'll often get a line like this.
Tap GENTLY on the screen bezel at both ends of the line.  If the line flickers with your tapping, this confirms this fault.  You can try to GENTLY bend the panel a little to make the connection work again.  It doesn't take much.  Which way you have to bend it depends on what happened, so you just have to play around.  This is a LAST RESORT as you're just as likely to make things way worse.
