Author Topic: pots to volume ?  (Read 1732 times)
ntk
  • Last login:June 06, 2011, 12:09:59 pm
pots to volume ?
« on: December 06, 2010, 05:34:42 am »
hello
i have the a-pac with 2 padels and i can add 2 more pots to the a-pac, so I thought to buy something like this
http://cgi.ebay.com/500KA-POTENTIOMETER-VOLUME-CONTROL-SMALL-SIZE-X2-/380139639108?pt=LH_DefaultDomain_2&hash=item5882169144
and control the volume, anyone know software that can control the volume using joystick ?
thanks
Blanka
Re: pots to volume ?
« Reply #1 on: December 06, 2010, 08:17:35 am »
You can map shift keys to volume keys on a Ultimarc pac.
bkenobi
« Reply #2 on: December 06, 2010, 12:04:17 pm »
Also, if your encoder doesn't support it (and you are running Windows or Linux), you can script something to take key combinations and turn them into volume increment/decrement.
ntk
« Reply #3 on: December 06, 2010, 01:19:19 pm »
thanks i know i can do it with the ipac but i want to make wheel instead of 2 buttons
bkenobi
« Reply #4 on: December 06, 2010, 11:10:58 pm »
If the apac output shows up as a joystick axis (which I believe it does), then you can use a script to convert joystick axis position to discrete volume setting.
ntk
« Reply #5 on: December 07, 2010, 02:12:21 am »
yes it shows joystick axis
but the problem i have no idea how to make a script :banghead: and also I could not find any software or Script that can do such a thing, so if someone know how and can help me.... I really appreciate it
thanks
bkenobi
« Reply #6 on: December 07, 2010, 10:33:46 am »
AHK or AI can do this easily.  In fact, there may even be something written and posted on their forums.
http://www.autohotkey.com/
http://www.autoitscript.com/autoit3/index.shtml
I'm a AHK person, so I'd check out the following functions and examples:
SetVolume (set the volume)
http://www.autohotkey.com/forum/topic9286.html
GetKeyState (determine the position of the joystick axis)
http://www.autohotkey.com/docs/commands/GetKeyState.htm
Remapping guides
Button/Keys/etc naming nomenclature
http://www.autohotkey.com/docs/KeyList.htm
Buttons/Keys
http://www.autohotkey.com/docs/misc/Remap.htm
Mouse/Joystick
http://www.autohotkey.com/docs/misc/RemapJoystick.htm
Joystick test script
http://www.autohotkey.com/docs/scripts/JoystickTest.htm
AFAIK, the joystick state for an analog axis is between 0 and 100.  The SetVolume command needs to be set between 0 and 100 also.  Thus, it should be a simple matter of poling for the position of the joystick and setting that value to the master volume.  You may want to try the joystick test script first to make sure AHK sees the axis correctly.
Good luck!   :cheers:
