Author Topic: One Coat Melamine Paint  (Read 9981 times)
Jollywest
  • Last login:Yesterday at 12:57:56 am
« on: November 19, 2010, 07:21:25 pm »
- One coat application
- No Primer Required
- Tough & durable
- Transform and refreshes
DIY Store - One Coat Melamine Paint
Sounds too good to be true. Has anyone had any experience of using such a product?
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
Re: One Coat Melamine Paint
« Reply #1 on: November 20, 2010, 09:08:02 pm »
Just wanted to jump in and give my 2 cents! I laminated my first cab! Was a bit of work but turned out nice! A bit expensive but I would say worth it in the end.
The cab I have just done, I decided to paint! Worst mistake ever! Absolute pain in the ass, sanding, painting more sanding, more painting etc! So I went to a local carpenter.  He showed me a sheet of melamine. He used regular old paint and sprayed on 1 rough coat of black semi-gloss paint and it turned out absolutely fantastic.  It would be extremely easy to get the piano black finish that people like without much work at all. 1 coat of paint and a buffer and it would be perfect.
I don't think it gets mentioned on this forum enough and would love to see more people building cabs with melamine as it appears to save a mountain of work in the painting side of things!
orchidius
  • Last login:January 30, 2013, 12:44:11 pm
« Reply #2 on: November 21, 2010, 03:07:10 am »
So... Recap... He used a melamine coated sheet of fibreboard like the ones used in most "older" kitchens and other furniture, then painted it with one layer of old paint and one layer of black semi-gloss from a spray-can and it that gave him the mirror black finish that normally require an infinite amount of sanding?
Nacimroc
« Reply #3 on: November 21, 2010, 07:16:30 am »
Yes, he used an mdf coated with melamine identical to the sheets used in the shelves of kitchen units. He gave it a single sprayed coat, but I could see that after a tiny amount more work, you could get a piano black finish. I can clearly see my reflection after one spray, so I'm assuming after a small amount of buffering, that perfect finish could be achieved after a few minutes work. After painting a cab and laminating a cab, this melamine looks like the perfect choice. Cheapish and a better finish.
orchidius
« Reply #4 on: November 21, 2010, 01:37:22 pm »
I'll most certainly keep it in mind! I considered that option before, but none of the DIY stores here in Belgium sell that type of wood. Well, they do sell it, but only in 50cm wide planks -.-
Jollywest
« Reply #5 on: November 22, 2010, 04:44:22 pm »
Interesting stuff... Thanks for your views.
I've just bought some of the paint anyhow and will report back after I've tried it.
On the tin it does say Melamine needs to be well sanded with 240 grit sandpaper first though.
Jollywest
« Reply #6 on: December 04, 2010, 07:16:40 am »
If anyone is thinking of using One-Coat Melamime Paint from Ronseal I would definitely recommend it.
It says that Melamine should be sanded with 240 grit sand paper first, but since there was a grain effect with little score marks everywhere on my cab I never bothered, as I though this would be enough of a key for the paint to stick to.
I followed the tin's application instructions which were;
- Use a Bristle Brush.
- Spread the paint out as much as possible.
- Finish with final brush stroke in one direction.
The finish was great, but it was slightly patchy in places, so I did a second coat on the visible parts and it looks fantastic now.
Pics to come.
  • Last login:Yesterday at 01:43:59 pm
« Reply #7 on: December 15, 2010, 03:19:19 pm »
Pics??   ;D
Jollywest
« Reply #8 on: December 15, 2010, 04:02:19 pm »
Yea sorry just been a bit busy but will try and sort them tomorrow.
Jollywest
« Reply #9 on: December 16, 2010, 04:03:04 pm »
Finally got chance to take some pics.
I plan to upload some better quality one's soon, never realised how blurry they were till I blew them up on the pc.
... and how it looked originally;
Jollywest
« Reply #10 on: February 08, 2011, 03:44:04 pm »
I know its been a while but here are some better quality pictures of the painted Melamine;
(There is also a little video that I posted in the Misc. forum - HERE)
