Author Topic: Quick help needed: simple admin button wiring diagram for IPAC  (Read 3129 times)
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
NOTE: I realize IPAC can be programmed - I just want a few dedicated Admin buttons.
I am doing the admin button wiring tonight, and I would like to know how that will work using an IPAC. And if I would need to change any MAME settings.
The front end I am using is ArcadeFX on Win98se.
The buttons will be behind the coin door on a Stern cab.
Can someone post a simple wiring diagram or explain clearly how the admin buttons will need to be wired up? My CP uses 2 joys w/6 buttons per player. 2 starts buttons and 2 coin buttons.
Admin Buttons I'd like to have:
-dedicated shift button for IPAC
-Tab
-Enter
-ESC
-Pause
I appreciate your help, in advance.
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
Inaba
  • Last login:December 14, 2004, 01:58:48 pm
  • Secret Squirrel
    • Cazic Thule Forums
Re:Quick help needed: simple admin button wiring diagram for IPAC
« Reply #1 on: August 14, 2003, 04:54:24 pm »
Here are my admin buttons, and how they are wired:
TAB
ENTER
ARROW UP
ARROW DOWN
ESC
Arrow up is wired to 1SW UP
Arrow dn is wired to 1SW Down
Enter is wired to 3SW 3 (?? I think that's default to Enter on an IPAC/4)
TAB is wired to 4SW8 and set manually in the iPAC config
ESC is wired to 4SW7 and set manually in the IPAC config
I was unable to get what I wanted out of the default MAME config on an ipac ... and incidentally, player 4 left is V... which is Player 1 SW 8 on an IPAC/4.  The default MAME setup for an IPAC/4 leaves a lot to be desired... I'd recommend changing it via the setup utility.  Even if you have an IPAC/2, programming it yourself will be helpful.
soslo
  • The Governator
« Reply #2 on: August 14, 2003, 05:29:07 pm »
So basically:
1. Use the 'unused' buttons on the IPAC
2. Re-program the IPAC to make 1SW7, 1SW8, 2SW7, and 2SW8 equal Tab, Enter, ESC, and Pause?
Wow, if that is it...I will feel really dumb...I guess I just wasn't thinking...
thanks
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: August 14, 2003, 05:39:36 pm »
Just that simple.  I setup player 1 button 7 on my ipac as a dedicated ESC and button 8 as a dedicated pause (and shift key).
soslo
  • The Governator
« Reply #4 on: August 14, 2003, 05:58:51 pm »
Is that the shift key on the keyboard or the shift key in the IPAC for the alternate commands?
Inaba
  • Secret Squirrel
« Reply #5 on: August 15, 2003, 12:34:48 pm »
Shift key on the IPAC.
You press the button that's labled as shift, then all the other inputs do the alternate shift stuff.
