Author Topic: External usb and headphone jacks.  (Read 2295 times)
justinjstark
  • Last login:May 14, 2021, 02:20:13 pm
« on: November 19, 2010, 04:46:13 pm »
I want to add ports on the outside of my cab so you can plug in headphones or usb microphones.  I found this which fits in a 60mm hole and would be pretty cool.  I'm curious what other solutions you guys have.
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
Re: External usb and headphone jacks.
« Reply #1 on: November 19, 2010, 04:59:35 pm »
I used http://frontx.com/       :cheers:
justinjstark
« Reply #2 on: November 19, 2010, 05:04:30 pm »
So you buy a panel and then you buy each port that you want in it individually?  I looked a frontx but it looks pricey to do that.
« Reply #3 on: November 19, 2010, 05:27:03 pm »
I just drilled out a hole just slightly smaller than the end of a USB ext cable, used a chisel and rask to get the size just right and epoxied the end of the extension cable into the hole. Looks great, pretty easy and a usb ext cable cost about 1.99$
I'm betting a headphone jack ext cable would be just a cheap and even easier cause it's probably round.
Franco B
« Reply #4 on: November 20, 2010, 06:14:56 am »
These Neutrik NAUSB - USB Feedthrough Chassis Socket are pretty good. You just need to drill a hole for the barell of the body and then you just screw it to your panel.
I'm looking for some low profile 3.5mm panel mount jacks myself at the moment.
I have seen these panel mount cables:
You can mount them into panels up to 2.5mm thick, I need to mount them in 3mm acrylic so I may just get away with it.
Another solution may be to use a panel mount jack something like this:
You/I could then just wire a 3.5mm cable to the terminals.
Depending on your application, another solution may just be to get a 3.5mm extension cable (kinda like the second pic) and then just drill a hole in your panel to suit the OD and glue it in place. I'm using a thin acrylic panel so that last method isn't really suitable, plus I want something clean and I also hate having to glue anything unless I absolutely have to.
justinjstark
« Reply #5 on: November 21, 2010, 03:52:48 pm »
I like this but I want more than one port...about 3 would be preferable.  Does anybody know of anything like this with multiple ports?
justinjstark
« Reply #6 on: November 21, 2010, 04:16:31 pm »
Also, I am looking at getting a stereo potentiometer to control the volume.  Does anybody know what resistance I should be looking at?  There are lots of options.
