Author Topic: Dreamcast VGA box problems  (Read 2650 times)
BurgerKingDiamond
« on: November 18, 2010, 07:06:52 am »
I just got a Dreamcast VGA box. The VGA doesn't work with my flatscreen (I have connected my computer through VGA to this TV before with no problems), although it does work with my room mates. Can anybody explain to me why my this is? I don't expect to fix it since it seems to be inherent with my TV (I got the box from Snaake, and he said it doesn't work with one of his TV's too). I am just curious as to why these TV's are being picky about which VGA signals to take.
The bigger problem for me is the s-video out that is also on the VGA box. This is the main issue for me because this is what I was planning on using it for. I have tried it with 2 CRT's which I know have working s-video inputs, through an s-video cable that I also know to be working fine. I also tried through s-video on a flatscreen.
On the two CRT's the opening dreamcast logo is still red, but the background is black instead of white. On one of the CRT's the picture isn't stable at all, it's kind of scrolling up and down and looks like total garbage. On the other CRT the picture is stable, but lined up way off center. I got absolutely nothing with the flatscreen.
I found some posts in other forum's with other people having the same issue of black picture using s-video. There weren't any helpful replies. Just the typical obvious stuff like "make sure the cable is working, make sure the TV input works".....
Can you help me?
BKD  :burgerking:
-Welcome to the Fantasy Zone.
  • Last login:July 23, 2025, 07:04:20 pm
Re: Dreamcast VGA box problems
« Reply #1 on: November 18, 2010, 09:17:12 am »
Hey, maybe you should make sure the cable is working, and the TV input, too...   :burgerking:
In all seriousness, though, have you tried using a different game?  There are a few games that are incompatible with the VGA box.
BurgerKingDiamond
« Reply #2 on: November 18, 2010, 09:58:31 am »
I have tried a few games, but I think that's just an issue with with VGA, not s-video, which is my main concern. I want to improve the picture on my cab which only has compnosite/s-video inputs.
And it won't even display the Dreamcast boot up screen correctly without a game, so that is not the problem...  :cry:
mgb
  • North East, US
« Reply #3 on: December 15, 2010, 07:52:52 am »
Yeah the game compatability is only with the VGA. I'm sure you have, but just to clarify, did you put the switch in the right position for selecting between vga and svideo.
Also I've noticed on mine that it is possible to plug the connector into the back of the dc and it seems to be plugged in all the way but then I get nothing and I need to snug in the connector.
As far as the vga goes too, the display needs to be able to do 640x480 (I assume all do).
hope it works for you
