Author Topic: What do chd files do?  (Read 1458 times)
GoTheBunnies
  • Last login:September 15, 2011, 06:10:09 am
« on: November 16, 2010, 04:36:33 am »
Hi guys,
New to MAME (as you can probably tell from the question), but what are chd files for?
I have a set of roms with matching chd files - where should the chd folder sit....directly under the roms folder? How does MAME know to look for the chd files (because the roms will run without them right?) - does it just know, or do I need to specify the folder location in the MAME setup somewhere?
dennislee13
  • Last login:March 31, 2011, 02:10:52 am
Re: What do chd files do?
« Reply #1 on: November 16, 2010, 07:47:46 am »
 CHD file is a compressed image of the hard drive used in an arcade cabinet used in arcade games as it requires more spaces. :) :)
BobA
  • What Me Worry?
« Reply #2 on: November 16, 2010, 09:20:48 am »
Games that have CHDs will not run without them.  I have my CHDs in the ROM directory with each CHD file in a directory with the same name but there is a newer way to set them up and I have not changed mine.
GoTheBunnies
« Reply #3 on: November 16, 2010, 04:56:09 pm »
Ok well that answer tells me that I must have them in the right place, or the games wouldn't be running (and they are). I thought the games would run anyway, but obviously not.....
