Author Topic: Instantsheller and mala problems  (Read 1757 times)
quadrider1
  • Last login:July 14, 2012, 11:41:42 am
« on: November 11, 2010, 11:13:46 pm »
So i have had mala load up fine with windows and all but wanted to shell it. Now when i shell it with instantsheller mala loads and says. MaLa.exe has encountered problems and needs to close. But if i go to it after it closes and starts it it will load up fine. What is up with it.
Gray_Area
  • -Banned-
  • -Banned-
Re: Instantsheller and mala problems
« Reply #1 on: November 13, 2010, 10:15:17 pm »
What are the exact settings in instantsheller you enabled?
-Banned-
quadrider1
« Reply #2 on: November 15, 2010, 08:35:49 pm »
switched to quick sheller and chose the autostart way. the shelling would always cause mala to crash for some reason.
loadman
  • Last login:May 12, 2026, 04:25:06 am
    • MaLa
« Reply #3 on: November 15, 2010, 09:23:07 pm »
Anything in the mala.exe.log file?
quadrider1
« Reply #4 on: November 16, 2010, 02:26:24 am »
I looked for the error log and could not find it in my MaLa folder. This happened with my previouse version of MaLa and MaLa 1.05. Its only the shelling part that makes mala stop. I remember it saying somthing wrong with compiling a menu in my last version of mala that i tried shelling.
