Author Topic: d9200  (Read 1840 times)
sega-rocks
  • Last login:November 06, 2010, 02:38:16 pm
d9200
« on: November 05, 2010, 10:53:19 am »
i have a d9200 that came out of a silver strike bowl it works fine do any of you monitor buffs think i should up grade to the 9400 chassis
lilshawn
  • Last login:Today at 05:18:38 pm
Re: d9200
« Reply #1 on: November 05, 2010, 07:43:02 pm »
if it works, keep it.
but if it fails, cut power to it right away, they are known to just keep dumping power into everything on the board and you have to replace 100 things to get it going again(if you can) i had 2 fail this way and they are not recoverable.
have a browse through this post i made earlier this year regarding this monitor and make your decision.
http://forum.arcadecontrols.com/index.php?topic=102349.0
sega-rocks
Re: d9200
« Reply #2 on: November 05, 2010, 10:26:16 pm »
it a 2004 monitor i think incredible technology have updated the componets on it because it crisp and works great to be 6 years old
lilshawn
Re: d9200
« Reply #3 on: November 06, 2010, 12:33:15 pm »
well the monitor itself is a great monitor. the picture is (read: can be) great, its just plagued with a few problems.
there is a few caps that need to be looked after. if its working right now, it would be VERY beneficial to change them before they fail and you have yourself a real issue. like the dude from wells gardner says, if it breaks down, it takes a whole whack of parts down with it. and generally it starts with either a faulty cap, or a blown HOT.
if you don't mind babysitting it, and regularly checking it every month or so (if your leaving it on), then it's fine. if you are only sporadically going to use it, it's fine too. but if you want something that you can stick in there and never have to worry about it again, it's probably best to look at something else.
sega-rocks
Re: d9200
« Reply #4 on: November 06, 2010, 02:27:31 pm »
so you think i should upgrade to the d9400 chassis i can get a new on for 150.00
