Author Topic: Help program codes for a rowe ami starlight  (Read 9099 times)
jpsb
  • Newbie
  • Last login:November 06, 2010, 09:48:30 am
« on: November 05, 2010, 09:22:47 am »
Hi, I have a rowe ami jukebox model is a starlight. Works great but someone lost the users manual and now I can't add a new CD because I don't know what codes to enter in. If anyone would be kind enough to tell me the codes for adding and removing a CD I would be very appreciative. Also the code for reset everything would be nice too. thanks in advance to any and all that help.
jim s
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Help program codes for a rowe ami starlight
« Reply #1 on: November 05, 2010, 10:29:54 am »
Hi Jim,
The codes for most Rowe Ami CD jukes is as follows:-
Go in Service the display should show SERVICE MODE
Type in 31 and the display will show PROGRAM INIT
Enter the CD numbers you changed and press POPULAR after each number
When you have entered all of the numbers put the service switch into the normal position and the mechanism will start to initialization process.
To initialize all the CD's type in 30.
Regards
Alan Hood
ami-man
UK
sarge
  • Last login:April 27, 2015, 01:42:54 pm
« Reply #2 on: November 06, 2010, 04:03:31 pm »
You can also hold reset and press 1 or 0 to scroll through the menu.  Hit popular to enter the menu.
