Author Topic: lists messing up  (Read 2193 times)
gazz292
  • Last login:January 22, 2022, 12:00:01 pm
lists messing up
« on: November 04, 2010, 10:59:01 am »
i posted this in the software section, forgetting about this section.....
having a problem with mala 1.72, (i did have the focus issue, but i shut down 'CLIstart' and it's fixed it.
but i'm having a weird thing happen,
i've just built my game lists up, i've got 'use tree' set to on, the all games tree works fine,
but any of the others, when i select a game, play it, then exit, it puts the game i just played at the top of the list...
i.e. say i was half way down a list, started a game called 'pppp' when i exit it's showing the top of the list with 'pppp' at the top,
if i start another game, lets say 'rrrr' when i exit the list has 'rrrr' at the top, next is 'pppp' then the normal list,
i have turned off the 'most played' list function, thinking it was that.... however i had that enabled, then i changed the lists about so i dont have a most played list, i thought maybe that had messed something up.
any one experianced this before?
gazz292
Re: lists messing up
« Reply #1 on: November 06, 2010, 08:51:54 pm »
Figured it out,
i just had to change the setting in mala to sort the lists by name, the main list was set at that, but all the ones i'd made were on 'sort by times played'
