Author Topic: Color Bleeding?  (Read 1846 times)
LunarLoveLust
  • Last login:October 14, 2016, 02:43:26 pm
  • n00b :D
Color Bleeding?
« on: August 13, 2003, 02:31:37 am »
I've heard talk of "color bleeding" when using TV's at an angle, is this true? And how quick, bad and just plain how and why does it happen?
Thankie  ;D
paigeoliver
  • Awesome face!
Re:Color Bleeding?
« Reply #1 on: August 13, 2003, 04:51:59 am »
Best way to avoid any color problems when using a TV at an angle is to start with a brand new TV. Install it at the angle you want it before you ever turn it on.
You shouldn't have a problem then.
I don't really understand why, but TVs (and indeed, even many arcade monitors), have a bit of a problem switching orientation or even angle after long periods of use at a different orientation or angle. Sometimes they will never quite get correctly deguassed.
LunarLoveLust
  • n00b :D
Re:Color Bleeding?
« Reply #2 on: August 13, 2003, 01:41:36 pm »
Sounds good, thanks :)
