Author Topic: what is the value of c551 on the power board of a wg k4600?  (Read 1964 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: October 24, 2010, 09:42:35 pm »
i stupidly removed all 3 caps from the power board only to find only 2 caps were included in capkit for c501 and c503.
c551 is not listed in the component list for the schematic i have :(
can any one advise which value cap i need to put back for c551?
MKFan4Life
  • Last login:July 24, 2023, 08:18:00 am
  • My arcade machines...
Re: what is the value of c551 on the power board of a wg k4600?
« Reply #1 on: October 25, 2010, 01:33:04 am »
I probably Googled the identical schematic and parts list you have and yeah, it only lists C501, C502, & C503 on that list.  BUT, since the list DOES show the values of those 3 caps, can't you just use that to eliminate C501 and C503 from the 3 caps you have on hand and the third one you have removed will define the value of C551 and you can either solder it back in or buy a new one to install in it's place if you prefer?
The schematic I looked at SEEMED to show C551, but it was so hard to make out, it could have been "C531", "C351", or "C331", just as well.  Very unclear.  Maybe your PCB shows the identity of it more clearly.
C501 is a "10uF 160V" cap and C503 is a "22uF 16V" cap.  So remove these from the 3 you desoldered and you should have C551 remaining.  Unless you tossed them or mixed them with the other caps from the pcb's you removed.
rchadd
  • Made in Cornwall
« Reply #2 on: October 25, 2010, 03:50:57 pm »
Ken Layton has confirmed that c551 is 220uF 16V
apparently some power pcbs have them and some don't
i chucked them all in a big pile of old caps :/
will take more care next time!
« Last Edit: October 26, 2010, 04:21:48 pm by rchadd »
MKFan4Life
« Reply #3 on: October 25, 2010, 06:31:40 pm »
I couldn't find the C551 value on a parts list by Googling.  Glad Ken helped you out.  Guess you'll pop a new puppy in there, huh?
Ken Layton
  • Guru
  • Technician
« Reply #4 on: October 26, 2010, 12:11:16 am »
Actually it should be 220 uf @ 16 volts.
