Author Topic: Topgun 2 hotd2 reloading problem (not shoot out of screen issue)  (Read 1679 times)
mr aize
  • Last login:December 16, 2013, 10:02:06 am
Hello everyone. First off, appologies if this has already been covered. I've had a little search of the site and couldn't find any mention of my particular issue, so here goes:
I've just bought 2 ems topgun 2 lightguns and i'm using them to play the pc version of house of the dead 2, running on a pc with windows 7. (I've also installed troubleshooter in order to use 2 lightguns on hotd2. But I don't think this has anything to do with the problem)
Basically, the problem is that the reload button has a tendancy to stop working. I'm using the guns on rapidfire mode (setting 1 on the guns) and reload is set to the handle trigger. It all works fine for the first level or so but then suddenly decides to stop reloading, usually just when a bunch of really hard bad guys show up. This is obviously really really annoying and I can't seem to find any solution or cause. Sometimes, if I hit pause, the reload button starts working again for a bit, but this only seems to be temporary and it basically makes the game unplayable. Any help very gratefully recieved!
mr aize
Re: Topgun 2 hotd2 reloading problem (not shoot out of screen issue)
« Reply #1 on: October 26, 2010, 02:39:30 pm »
No one? Anyone know where I should ask? Help please as i'm more than a little gutted about this..
ark_ader
  • I glow in the dark.
« Reply #2 on: October 26, 2010, 02:59:21 pm »
Yeah I know what you mean.  I just got a projector and wanted to play HOTD too in HUGE glory. But your issue isn't in just Windows 7, but also in XP.
Yes I:
1 loaded the drivers from the disc // Not Joy
2 unloaded the drivers via safe mode
3 reinstalled drivers from web page again
4 Played for a while then the player 2 gun stopped responding and no off screen reload then nothing (the Laser pointer stopped underneath the gun).
5 goto 2  //gave up
6 Fired up the Xbox with HOTD
7 Worked fine without recoil!
8 Got in trouble for mounting the led bars on the kitchen wall.
So use white tack for the walls and use a $20 Xbox.
 :laugh2:
« Last Edit: October 26, 2010, 03:04:56 pm by ark_ader »
mr aize
« Reply #3 on: October 26, 2010, 04:34:05 pm »
Arse! How annoying!!! Anyone know if this problem happens with the mame sega version as well? Running the pc one at the moment but bought a load of dvds with the latest mame emulator and the house of the dead series (apparently) in there..
