Author Topic: Touchstone FPM1001 15" USB Touch Screen  (Read 10217 times)
ror
  • Last login:November 03, 2010, 08:39:14 pm
« on: October 22, 2010, 12:28:57 am »
Hi, I just bought an 3M Touchstone FPM1001 15" USB Touch Screen LCD Monitor on ebay. (Have not got it yet) Just wondering if anyone has or knows about this monitor and if/where I can to get drivers for windows7. I found some software at http://solutions.3m.com/wps/portal/3M/en_US/TouchSystems/TouchScreen/CustomerSupport/TouchScreenDrivers/ but this monitor was not listed on there site.
It was while searching for said drivers that I came across this site and very glad I did. Hope I can contribute in the future.
Kevin Mullins
    • Me on Myspace
Re: Touchstone FPM1001 15" USB Touch Screen
« Reply #1 on: October 23, 2010, 09:25:46 am »
The latest set of drivers should work for that one - MT 7.13 Build 1
ror
« Reply #2 on: October 24, 2010, 02:13:23 pm »
Thank you Kevin, will give it a try when I get the screen. By the way I plan on building something with a built in D class amp. Any projects I should look at ?
ror
« Reply #3 on: October 28, 2010, 10:06:13 pm »
Thanks again Kevin, those drivers work! I am testing this on XP and the only thing that does not work is double click (double touch) while everything else works great. Any pointers? I take it if I can get it to work in XP then Win7 should be a go?
Kevin Mullins
    • Me on Myspace
« Reply #4 on: October 30, 2010, 01:47:52 pm »
I run version 7.12 mostly just because I hadn't needed anything newer....but in its "Control Panel" there are some touch settings that you might want to play with.
Look for Microtouch in your programs list.
Set it to DRAWING for sure if you have that option.
And then play with some of the double click options to your liking.
As for Win7 .... you're just going to have to give it a try.
(I don't use it for anything, so never tried any drivers for it)
