Author Topic: would it be ok to use 8liners chassis  (Read 1770 times)
adidas1984x
  • Last login:January 06, 2023, 07:14:53 am
« on: October 21, 2010, 07:42:34 am »
Just for future purposes if i have a chassis go bad on my wg u2000 monitor or my neotec would it be ok to do this
please read link
http://retroblast.arcadecontrols.com/articles/8-Liners_1.html
adidas1984x
Re: would it be ok to use 8liners chassis
« Reply #1 on: October 26, 2010, 08:09:04 pm »
has anybody else used this ???
Ken Layton
  • Guru
  • Technician
« Reply #2 on: October 27, 2010, 12:41:20 am »
The "universal" replacement monitor chassis out there are for the most part STANDARD resolution (a.k.a. "CGA" ). That means they can only be used to replace an original monitor chassis that was standard resolution.
The Wells-Gardner model U2000 is standard resolution.
Neotec manufactures monitor models in several resolutions. Exact model number of the original chassis is important.
Remember, that these universal replacement monitor chassis are designed for certain specifications. In particular the yoke impedance and the picture tube neck diameter.
Also, since the time that article was written, 8liners.com (a.k.a. genao.com and Atlas Amusement) no longer sells the Jen Shinn brand replacement chassis. They now sell only the Wei-ya (a.k.a. Huai Electronics) brand line of replacement chassis.
http://www.8liners.com/datatech/monitor.html
adidas1984x
« Reply #3 on: October 27, 2010, 10:13:17 am »
yes both of my chassis are standard resolution just for future would the new chassis he sell work?
Ken Layton
  • Guru
  • Technician
« Reply #4 on: October 27, 2010, 11:38:47 am »
You have to measure the yoke impedance, tube size, tube pin count (neck diameter too). Then you contact Victor at 8liners.com with that information as mentioned in that link I gave. Then he will tell you if he has a chassis that works with those specifications.
