Author Topic: Trackball feedback (want your opinion)  (Read 1816 times)
Donkbaca
    • Slim built MAME/Xbox cab
« on: October 20, 2010, 12:49:58 pm »
In the midst of building my CP, I will post photos of the build when I am a bit further along.  However I wanted to get the community's opinion on something:
Currently I am not putting a Track Ball on my CP, because i don't want to take up the real estate on my CP, and I want to keep my CP pretty clean and uncluttered and I am not a huge fan of trackball games.  However, the more I think about it, the more I am thinking that maybe I might want to add a trackball later, so I got to thinking.  I am planning on having a hinged cubby area between my CP and coin door instead of a keyboard drawer as a place to stow lightguns and wireless 360 controllers for console emulation. I remember X-Arcade made a trackball controller, but I don't think they make it anymore.  here is a picture of it:
http://www.amazon.com/X-Arcade-Trackball/dp/B000CD53RA
I could maybe make one.  It would basically it would be a USB trackball in a box buttons on the side.  I could pull this out from my storage area and rest it on my CP  between the 1p and 2p controlls where a trackball would go.controllers. Any ideas on what the dimensions should be?  Should I just nix the idea?  I am pretty against installing a trackball on the CP itself...
dfmaverick
Re: Trackball feedback (want your opinion)
« Reply #1 on: October 20, 2010, 12:58:06 pm »
I'd say if you are set against putting a trackball on your CP, then just complete your project since a decision on an exterior trackball won't change that.
Play for a bit. If you decide that you have enough need for your "trackball in a box", then you can always do it later.
Size of the box would probably depend upon the trackball you select.
severdhed
  • RIP Dinosaur Hippo
« Reply #2 on: October 20, 2010, 04:13:36 pm »
i say, if you dont think you want a trackball, then don't bother.   i didn't have a trackball in my panel for a long time, until a friend showed me centipede after we built his panel..then i had to have one.  so i added it later.  my point is, that unless you are really awesome, you will probably not make your panel perfect the first time.  i have had so many revisions to my control panel, that i lost count.  make the panel the way you want, and try it for a while.  you can always make a new one later....or even a second cabinet.  i had a 2 player setup with two u360s and a trackball, now i have two cabinets... a 4player panel with only 8way joysticks and buttons, and a second cabinet with a vertical monitor, tracbkall and 4 way stick.
