Author Topic: OEM Flipper switches to IPAC  (Read 4423 times)
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
« on: October 14, 2010, 12:55:54 am »
Can someone explain these to me
Due to the proximity of the plunger I cant use a standard Happ button with Microswitch, so ive got to use the original switches that the original flipper buttons pushed, but how do you wire them to the IPAC?
Is one tab +  and the other -   ? Why the resistor if thats what it is?
My MAME Build:
Q*Bert_OP
  • Oh yes, we did!
Re: OEM Flipper switches to IPAC
« Reply #1 on: October 14, 2010, 01:06:01 am »
That's a spark suppression capacitor...those switches are for high current applications. You can and should remove that capacitor...solder your wires to the bottom tabs. Since that is a high current switch, it has tungsten contacts, not recommended for low current, but it will work. On the other hand, low current gold plated contacts must NEVER be used in high current applications...this causes excessive sparking and a fire hazard.
Smeghead
    • MY MAME BUILDS
« Reply #2 on: October 14, 2010, 01:20:08 am »
So negative to one tab and positive to the other?  Just like a microswitch?
My MAME Build:
Q*Bert_OP
  • Oh yes, we did!
« Reply #3 on: October 14, 2010, 09:48:30 am »
Yes. Use the bottom tabs, remove the capacitor from the side tabs...don't worry about those...they are in parallel with the bottom tabs.
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: October 14, 2010, 11:09:55 am »
I stuck gold plated contacts on a Comet flipper mech once, and it didn't spark anymore than the tungsten switch.
 :dunno
I'd show you some gold plated switches with holes in them, but I threw them out. They sparked and smoked with each closure.
Smeghead
    • MY MAME BUILDS
« Reply #5 on: October 14, 2010, 01:13:45 pm »
ok your scaring me, should I not use these????
My MAME Build:
Smeghead
    • MY MAME BUILDS
« Reply #6 on: October 14, 2010, 02:45:06 pm »
I duno, im just wiring the damn things straight to the IPAC like normal so I guess not
My MAME Build:
Q*Bert_OP
  • Oh yes, we did!
« Reply #7 on: October 14, 2010, 05:13:22 pm »
Then you're fine.
Yep...and Jim don't ever put gold contacts in a high voltage circuit   :whap
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #8 on: October 14, 2010, 06:15:22 pm »
Then you're fine.
Even if they have a diode and capacitor attached?
NO MORE!!
