Author Topic: Possible to have a master list of favorites / games that spans all emulators?  (Read 4231 times)
leperisland
  • Last login:October 18, 2010, 02:43:08 pm
Hi - I have moved this post from software:
Posted by: nickynooch
Insert Quote
You may getting a faster response and more responses on the maximus arcade section of the byoac board.  If you have future questions, post here:
http://forum.arcadecontrols.com/index.php?board=46.0
That said, to answer your question.  No.  That feature is not available in maximus arcade.  Just favorites per system.  IE, Nes favorites, MAME favorites, etc.
However, a workaround that would do what you asked for...
You could make the "batch files" section encompass all your favorites and do what you are asking, but that would require making a batch file for each game you want in your favorites.  That would be somewhat more time consuming than simply hitting a button and having it show up, but it would work.  I have had some MAME games, NES games etc in my batch files section and it works fine.
Posted on: Yesterday at 12:26:48 PM
Posted by: leperisland
Insert Quote
Hi there,
is it possible to have a master favorites or games list that spans all the installed emulators?
Thanks.
Has anyone tried anything like this? Perhaps its possible to write a batch file that scans several rom folders.
Thanks.
leperisland
I'd love the example batch - ALSO I'll probably write a PHP script to auto generate the batch files so you can add that to your tutorial :D
HOWEVER, i might also look into gameex as I think that does it by default
