Author Topic: Which one is hot? Which is neutral?  (Read 2093 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: September 28, 2010, 04:03:12 pm »
I'm installing a pigtail into a plug.  Does the big slot on an American plug correspond to the live or the neutral conductor?  Alternatively are live and neutral consistently represented by brass vs. silver screws?  If so which color for which?
Thanks.
Best Kid iPad Apps
padstack
  • Last login:February 03, 2024, 12:54:24 pm
Re: Which one is hot? Which is neutral?
« Reply #1 on: September 28, 2010, 04:10:33 pm »
Thanks.
Someone will correct me if I'm wrong, but I believe brass is always the hot (black) wire.
BobA
  • What Me Worry?
« Reply #2 on: September 28, 2010, 04:20:50 pm »
Wide blade is the neutral.   If you have colored screws the brass colored screw is for black (hot) and the silver screw is white (neutral)  The green is ground.
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
« Reply #3 on: September 28, 2010, 04:22:37 pm »
nm
My MAME Build:
shmokes
    • Jake Moses
« Reply #4 on: September 28, 2010, 05:51:51 pm »
Thanks.  All set.
Best Kid iPad Apps
