Author Topic: Arcade Speaker Types  (Read 4698 times)
gShooter
  • Last login:March 10, 2016, 02:12:46 pm
« on: September 19, 2010, 02:21:25 pm »
So I am at the point of installing/replacing the original speaker that was in an old Galaxian cabinet.  It's a 6x9 and lists its impedence at 60 ohms.
My questions are, since I am installing a 60v1 board, does anyone know:
1. what the impedence should be for a new speaker?
2. does it really matter what the ohms are ( 4 or 8 )
3. anyone have any experience installing car speakers for this type of project
Thanks in advance...
« Last Edit: September 19, 2010, 03:31:39 pm by gShooter »
BobA
  • What Me Worry?
Re: Arcade Speaker Types
« Reply #1 on: September 20, 2010, 09:53:32 am »
From Jammaboards
SPEAKER
Most regular JAMMA arcade games are just fine with a single 8-ohm speaker installed. Some JAMMA+ type games can support Stereo speakers and require an extra cable that connect directly from the arcade board to the left and right 8-ohm speakers.  Usually, the speaker(s) would be mounted above the monitor facing downward towards the player.
Click below to view typical arcade speakers:
http://www.jammaboards.com/store/standard-arcade-speaker-8-ohm-5-watt/prod_280.html
On the 60 in 1 boards there can be hum on the jamma speaker connection.   Using an amplified speaker and the sound jack on the board this hum is eliminated.
gShooter
« Reply #2 on: September 20, 2010, 01:31:21 pm »
Thx for the reply.  I read the same info on the Jamma site, but I wanted a local source for buying the actual speakers.  I went through a few vendors and auto parts stores, but I havent found a 8 ohm speaker yet.  Plenty of 4 ohm speakers, no 8s.
Unfortunately, the manual supplied with the 60v1 board does not show a complete connector layout of the board so its a guesstimate on the audio connector.
In the end, I'll probably just get a amplified set of computer speakers and either run the JAMMA harness to that, o play with what I think is the audi port on the board.
I also came across a post earlier that said they simply installed 2 - 4 ohm speakers in series which effectively equalled 1 - 8 ohm speaker.
BobA
  • What Me Worry?
« Reply #3 on: September 20, 2010, 06:22:07 pm »
The normal speaker connection in the jamma harness is L and 10.  An amplified set of speakers plugged into the audio jack on the board is probably a simple way to go.   2 4 ohm speakers in series does equal 8 ohms  just make sure plus goes to minus on the speakers so you are left with one plus and one minus so the speakers will be in phase.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: September 27, 2010, 03:25:35 pm »
Galaxian was shipped with a 8 ohm 6" by 9" speaker from the factory.
gShooter
« Reply #5 on: September 28, 2010, 10:02:33 pm »
Thx.  Thats the same info I found in the manual.  It would be authentic if I had the original pcbs, but alas I am missing most of the guts.  I ended up buying a pair of amplified speakers for the multicade board - Logitech X-140s.
« Last Edit: September 29, 2010, 09:50:09 am by gShooter »
